Astro A20 Microphone Replacement
  1. Astro A20  Microphone Replacement, Cushion: step 1, image 1 of 1
    • Place one hand on the hard side of the headset ear portion and on the cushion.
    • Lift the small portion on the edge of the cushion.
  2. Astro A20  Microphone Replacement: step 2, image 1 of 1
    • Slide the metal spudger underneath the lift part of the ear cushion.
    • Pull the ear cushion while wedging the spudge around the edge of the ear cushion.
  3. Astro A20  Microphone Replacement: step 3, image 1 of 2 Astro A20  Microphone Replacement: step 3, image 2 of 2
    • Remove the ear cushion from the headset.
  4. Astro A20  Microphone Replacement, Microphone: step 4, image 1 of 1
    • Place one hand on the back of the speaker.
  5. Astro A20  Microphone Replacement: step 5, image 1 of 2 Astro A20  Microphone Replacement: step 5, image 2 of 2
    • Remove the four 7mm screws with a Phillips #1 screwdriver.
    • You may want to use a 60mm screwdriver extension to reach the screws inside of the headset.
  6. Astro A20  Microphone Replacement: step 6, image 1 of 2 Astro A20  Microphone Replacement: step 6, image 2 of 2
    • Lift the speaker area.
    • Disconnect the wires that connect the microphone.
    • Remove the 7mm screw with a Phillips #1 screwdriver.
9 other people completed this guide.
5 Guide Comments
worked for me….thanks
Thompson Crusher - Reply
listen my mic peace is messed up is there like a fix for that
Bruh Bruh - Reply
were? are you getting the new mic from? please link the site
jrod6t9 - Reply
this really worked! There was no need to get a replacement mic since it was just a torn cable not making good contact. Thanks a lot!
Lineth Jauregui - Reply
Past 24 Hours: 7
Past 7 Days: 36
Past 30 Days: 136
All Time: 14,770
