Astro A20 Speaker Replacement
  1. Astro A20  Speaker Replacement, Cushion: step 1, image 1 of 1
    • Place one hand on the hard side of the headset ear portion and on the cushion.
    • Lift the small portion on the edge of the cushion.
  2. Astro A20  Speaker Replacement: step 2, image 1 of 1
    • Slide the metal spudger underneath the lift part of the ear cushion.
    • Pull the ear cushion while wedging the spudge around the edge of the ear cushion.
  3. Astro A20  Speaker Replacement: step 3, image 1 of 2 Astro A20  Speaker Replacement: step 3, image 2 of 2
    • Remove the ear cushion from the headset.
  4. Astro A20  Speaker Replacement, Speaker: step 4, image 1 of 1
    • Place your hand on the opposite side of the speaker.
  5. Astro A20  Speaker Replacement: step 5, image 1 of 2 Astro A20  Speaker Replacement: step 5, image 2 of 2
    • Remove the four 7mm screws with a Phillips #1 screwdriver.
    • You may want to use a 60mm screwdriver extension to reach the screws inside of the headset.
  6. Astro A20  Speaker Replacement: step 6, image 1 of 2 Astro A20  Speaker Replacement: step 6, image 2 of 2
    • Lift the speaker area.
    • Disconnect the wires connected to the speaker.
    • Wedge a spudger on the edge of the speaker and lift upwards to remove the speaker from the device.
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 68
All Time: 8,846
