Astro A40 Gen2 Speaker Replacement
  1. Astro A40 Gen2 Speaker Replacement, Ear Pad: step 1, image 1 of 2 Astro A40 Gen2 Speaker Replacement, Ear Pad: step 1, image 2 of 2
    • Pull one corner of the pad to release it from the headset.
    • Pull the rest of the ear pad off.
  2. Astro A40 Gen2 Speaker Replacement, Speaker: step 2, image 1 of 2 Astro A40 Gen2 Speaker Replacement, Speaker: step 2, image 2 of 2
    • Locate the four 4.5 mm Philips #0 screws on the panel shown.
    • Remove them using a Phillips #0 head screwdriver.
    • Remove the panel.
  3. Astro A40 Gen2 Speaker Replacement: step 3, image 1 of 2 Astro A40 Gen2 Speaker Replacement: step 3, image 2 of 2
    • Using either your fingers or a plastic opening tool, pry off the speaker cover.
  4. Astro A40 Gen2 Speaker Replacement: step 4, image 1 of 1
    • Locate the four 4.5 mm Philips #0 screws as shown on the speaker housing.
    • Remove the four screws using a Phillips #0 head screwdriver.
  5. Astro A40 Gen2 Speaker Replacement: step 5, image 1 of 1
    • Remove the housing to reveal the speaker.
    • Make sure not to break the small wire holding the two portions together.
Donavan Feliz
444 Reputation
2 Guides authored
Cal Poly, Team 20-18, Maness Winter 2015 Member of Cal Poly, Team 20-18, Maness Winter 2015
CPSU-MANESS-W15S20G18
4 Members
10 Guides authored
2 Guide Comments
Where do you buy the replacement speaker ? Thanks.
Steve Rosam - Reply
what speakers can these be replaced with? this guide is a little short on details about the actual removal and replacement of the speakers. the information here is just the start
Jasper W (Spike229) - Reply
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 20
All Time: 4,759
