Astro A40 TR Plus Mixamp M80 Headband Replacement
  1. Astro A40 TR Plus Mixamp M80 Headband Replacement, Headband Adjusters: step 1, image 1 of 3 Astro A40 TR Plus Mixamp M80 Headband Replacement, Headband Adjusters: step 1, image 2 of 3 Astro A40 TR Plus Mixamp M80 Headband Replacement, Headband Adjusters: step 1, image 3 of 3
    • Use a screwdriver with a H2.0 head to remove the two screws on the upper headband plate.
    • Use a screwdriver with a T9 bit to remove one screw from the upper headband plate.
    • Remove the upper headband plate.
    • Repeat the past three steps for the upper headband plate on the other side.
  2. Astro A40 TR Plus Mixamp M80 Headband Replacement: step 2, image 1 of 3 Astro A40 TR Plus Mixamp M80 Headband Replacement: step 2, image 2 of 3 Astro A40 TR Plus Mixamp M80 Headband Replacement: step 2, image 3 of 3
    • Use a screwdriver with a H2.0 head to remove the two screws on the lower headband plate.
    • Use a screwdriver with a T9 bit to remove one screw from the lower headband plate.
    • Remove the lower headband plate.
    • Repeat the past three steps for the lower headband plate on the other side.
  3. Astro A40 TR Plus Mixamp M80 Headband Replacement: step 3, image 1 of 1
    • Use your hand to remove the headband adjuster.
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 27
All Time: 2,899
