Astro A50 2016 Headset Speakers Replacement
  1. Astro A50 2016 Headset Speakers Replacement, Headset Speakers: step 1, image 1 of 2 Astro A50 2016 Headset Speakers Replacement, Headset Speakers: step 1, image 2 of 2
    • Remove the magnetic ear pads by gently pulling up away from the head set.
  2. Astro A50 2016 Headset Speakers Replacement: step 2, image 1 of 1
    • Squeeze the plastic opening tool between the black plastic and foam pad on non mic side and then pry upwards to remove the felt pads covering the speaker.
  3. Astro A50 2016 Headset Speakers Replacement: step 3, image 1 of 1
    • Remove the four 6mm Phillips 1 screws.
  4. Astro A50 2016 Headset Speakers Replacement: step 4, image 1 of 1
    • Lift the speaker module up off the device.
5 other people completed this guide.
Vincent Seguin
379 Reputation
3 Guides authored
Cal Poly, Team S15-G1, Livingston Fall 2017 Member of Cal Poly, Team S15-G1, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G1
3 Members
10 Guides authored
5 Comments
Great, pictures and explaining. But where do i get an speaker to replace the old one?
D3EW D - Reply
I am also looking for the replacement speakers. They seem impossible to find
Steven Fleck -
hola me encantaria que me pudieran decir donde comprar el repuesto de uno de los altavocez, porque no encuentro nada
ruben el gay - Reply
Awesome, but I don’t believe see anywhere on how to fix the mic as it rotates 360 free spinning rather than locking in the 90° talk and mute positions…?
Tippio - Reply
this is almost no solution, your cover is broken, there is stop on plastic cover.
X Pi Acoustic(CN) -
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 53
All Time: 6,615
