Astro Mixamp Motherboard Replacement
  1. Astro Mixamp Motherboard Replacement, Panel Dial: step 1, image 1 of 2 Astro Mixamp Motherboard Replacement, Panel Dial: step 1, image 2 of 2
    • Grip the dial tightly and pull straight off the device.
    • Repeat for the second dial
  2. Astro Mixamp Motherboard Replacement: step 2, image 1 of 2 Astro Mixamp Motherboard Replacement: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, remove the spacer nuts and washers from each dial post.
  3. Astro Mixamp Motherboard Replacement, Outer Casing: step 3, image 1 of 2 Astro Mixamp Motherboard Replacement, Outer Casing: step 3, image 2 of 2
    • Before opening your device, ensure the device is not on or connected to the charging cable.
    • Insert a plastic opening tool into the seam between the rubber foot and plastic casing.
    • Pull the rubber foot free of the plastic casing.
  4. Astro Mixamp Motherboard Replacement: step 4, image 1 of 1
    • Use a screwdriver to remove the screw from the rear casing.
  5. Astro Mixamp Motherboard Replacement: step 5, image 1 of 1
    • Gently lift the rear casing from the device.
  6. Astro Mixamp Motherboard Replacement, Motherboard: step 6, image 1 of 3 Astro Mixamp Motherboard Replacement, Motherboard: step 6, image 2 of 3 Astro Mixamp Motherboard Replacement, Motherboard: step 6, image 3 of 3
    • Remove the four screws that hold the motherboard in place.
    • Only touch the edges of the motherboard. Touching the surface can damage the motherboard.
  7. Astro Mixamp Motherboard Replacement: step 7, image 1 of 1
    • Gently pull the motherboard from the front cover.
Hope Burns
741 Reputation
5 Guides authored
IUPUI, Team 3-3, Wilson Fall 2016 Member of IUPUI, Team 3-3, Wilson Fall 2016
IUPUI-WILSON-F16S3G3
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 18
All Time: 2,373
