Astro Mixamp Outer Casing Replacement
  1. Astro Mixamp Outer Casing Replacement, Outer Casing: step 1, image 1 of 2 Astro Mixamp Outer Casing Replacement, Outer Casing: step 1, image 2 of 2
    • Before opening your device, ensure the device is not on or connected to the charging cable.
    • Insert a plastic opening tool into the seam between the rubber foot and plastic casing.
    • Pull the rubber foot free of the plastic casing.
  2. Astro Mixamp Outer Casing Replacement: step 2, image 1 of 1
    • Use a screwdriver to remove the screw from the rear casing.
  3. Astro Mixamp Outer Casing Replacement: step 3, image 1 of 1
    • Gently lift the rear casing from the device.
Hope Burns
741 Reputation
5 Guides authored
IUPUI, Team 3-3, Wilson Fall 2016 Member of IUPUI, Team 3-3, Wilson Fall 2016
IUPUI-WILSON-F16S3G3
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 1,843
