Astro Mixamp USB Port Replacement
  1. Astro Mixamp USB Port Replacement, Panel Dial: step 1, image 1 of 2 Astro Mixamp USB Port Replacement, Panel Dial: step 1, image 2 of 2
    • Grip the dial tightly and pull straight off the device.
    • Repeat for the second dial
  2. Astro Mixamp USB Port Replacement: step 2, image 1 of 2 Astro Mixamp USB Port Replacement: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, remove the spacer nuts and washers from each dial post.
  3. Astro Mixamp USB Port Replacement, Outer Casing: step 3, image 1 of 2 Astro Mixamp USB Port Replacement, Outer Casing: step 3, image 2 of 2
    • Before opening your device, ensure the device is not on or connected to the charging cable.
    • Insert a plastic opening tool into the seam between the rubber foot and plastic casing.
    • Pull the rubber foot free of the plastic casing.
  4. Astro Mixamp USB Port Replacement: step 4, image 1 of 1
    • Use a screwdriver to remove the screw from the rear casing.
  5. Astro Mixamp USB Port Replacement: step 5, image 1 of 1
    • Gently lift the rear casing from the device.
  6. Astro Mixamp USB Port Replacement, Motherboard: step 6, image 1 of 3 Astro Mixamp USB Port Replacement, Motherboard: step 6, image 2 of 3 Astro Mixamp USB Port Replacement, Motherboard: step 6, image 3 of 3
    • Remove the four screws that hold the motherboard in place.
    • Only touch the edges of the motherboard. Touching the surface can damage the motherboard.
  7. Astro Mixamp USB Port Replacement: step 7, image 1 of 1
    • Gently pull the motherboard from the front cover.
  8. Astro Mixamp USB Port Replacement, USB Port: step 8, image 1 of 3 Astro Mixamp USB Port Replacement, USB Port: step 8, image 2 of 3 Astro Mixamp USB Port Replacement, USB Port: step 8, image 3 of 3
    • Press the tip of a hot soldering iron to the USB connection to melt the solder.
    • Use a nylon spudger to lift the USB from the solder.
    • Repeat for each of the four USB connections.
    • For more help on soldering, refer to this guide: How To Solder and Desolder Connections
2 other people completed this guide.
Hope Burns
741 Reputation
5 Guides authored
IUPUI, Team 3-3, Wilson Fall 2016 Member of IUPUI, Team 3-3, Wilson Fall 2016
IUPUI-WILSON-F16S3G3
3 Members
5 Guides authored
4 Comments
What port is used as a replacement?
jonescoleman1738 - Reply
Did you ever identify an appropriate replacement port?
Lepec -
something was broken out of the port of the USB connection
MoreZemtor - Reply
Will this method work with the 2015 tr mixamp?
jeffreyalvarez9 - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 27
All Time: 7,924
