Astro Pyle PTBL7C Speakers Replacement
  1. Astro Pyle PTBL7C Speakers Replacement, Case Separation: step 1, image 1 of 2 Astro Pyle PTBL7C Speakers Replacement, Case Separation: step 1, image 2 of 2
    • Slide the flat end of the spudger under the front edge of the screen and carefully pry it open.
    • The front edge is the side with the buttons on it.
    • You may hear a cracking sound when pulling the case off of the device. This is normal, and is just the clips being pulled apart. However, be careful and pull the clips slowly/cautiously to avoid damage.
    • Be aware of the speaker cable when removing the case, as it is still attached to the motherboard.
  2. Astro Pyle PTBL7C Speakers Replacement, Tape Removal: step 2, image 1 of 1
    • Locate the Speakers; they should be attached to the case as shown.
    • Follow the wires back to the motherboard, removing all tape covering the wires along the way.
    • This will make it easier to move the wires around.
    • Desolder the black wire from the motherboard. This will separate the speakers from the board, allowing you to replace them.
    • Exercise EXTREME caution while soldering. It is very easy to burn yourself, or damage the surrounding components. For a basic guide of how to desolder, follow this link: http://www.dummies.com/programming/elect...
Abdulelah
214 Reputation
2 Guides authored
IUPUI, Team 5-5, Wilson Fall 2016 Member of IUPUI, Team 5-5, Wilson Fall 2016
IUPUI-WILSON-F16S5G5
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 240
