Asus A52F Cooling System Replacement
  1. Asus A52F Cooling System Replacement, Battery: step 1, image 1 of 2 Asus A52F Cooling System Replacement, Battery: step 1, image 2 of 2
    • Place the laptop face down with the battery facing away from you.
    • Locate the two buttons next to the battery.
    • Slide the right slider to the unlocked (red) position.
  2. Asus A52F Cooling System Replacement: step 2, image 1 of 2 Asus A52F Cooling System Replacement: step 2, image 2 of 2
    • Hold the left button to the left.
    • Slide the battery with your other hand away from you and it should disconnect.
  3. Asus A52F Cooling System Replacement, Lower Case: step 3, image 1 of 3 Asus A52F Cooling System Replacement, Lower Case: step 3, image 2 of 3 Asus A52F Cooling System Replacement, Lower Case: step 3, image 3 of 3
    • Remove the five Phillips # 0 screws from the back panel.
    • Using your finger or a plastic spudger start to carefully pry up the back planel.
  4. Asus A52F Cooling System Replacement: step 4, image 1 of 2 Asus A52F Cooling System Replacement: step 4, image 2 of 2
    • Slide the back panel away and remove the panel.
  5. Asus A52F Cooling System Replacement, Cooling System: step 5, image 1 of 2 Asus A52F Cooling System Replacement, Cooling System: step 5, image 2 of 2
    • Removal of cooling system will void your warranty. Proceed with caution.
  6. Asus A52F Cooling System Replacement: step 6, image 1 of 2 Asus A52F Cooling System Replacement: step 6, image 2 of 2
    • Using a Phillips #0 screwdriver, remove all six screws from the cooling system.
    • Unplug the fan power connector.
  7. Asus A52F Cooling System Replacement: step 7, image 1 of 2 Asus A52F Cooling System Replacement: step 7, image 2 of 2
    • Carefully grab the copper pipe and start to lift upward.
    • Lift to the angle shown and then start to slide it out.
  8. Asus A52F Cooling System Replacement: step 8, image 1 of 1
    • Clean the designated area with isopropyl alcohol on a microfiber cloth
    • Replace with new thermal paste if needed
2 other people completed this guide.
Bradley Varnum
297 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 1,118
