Asus A52F Hard Drive Replacement
  1. Asus A52F Hard Drive Replacement, Battery: step 1, image 1 of 2 Asus A52F Hard Drive Replacement, Battery: step 1, image 2 of 2
    • Place the laptop face down with the battery facing away from you.
    • Locate the two buttons next to the battery.
    • Slide the right slider to the unlocked (red) position.
  2. Asus A52F Hard Drive Replacement: step 2, image 1 of 2 Asus A52F Hard Drive Replacement: step 2, image 2 of 2
    • Hold the left button to the left.
    • Slide the battery with your other hand away from you and it should disconnect.
  3. Asus A52F Hard Drive Replacement, Lower Case: step 3, image 1 of 3 Asus A52F Hard Drive Replacement, Lower Case: step 3, image 2 of 3 Asus A52F Hard Drive Replacement, Lower Case: step 3, image 3 of 3
    • Remove the five Phillips # 0 screws from the back panel.
    • Using your finger or a plastic spudger start to carefully pry up the back planel.
  4. Asus A52F Hard Drive Replacement: step 4, image 1 of 2 Asus A52F Hard Drive Replacement: step 4, image 2 of 2
    • Slide the back panel away and remove the panel.
  5. Asus A52F Hard Drive Replacement, Hard Drive: step 5, image 1 of 3 Asus A52F Hard Drive Replacement, Hard Drive: step 5, image 2 of 3 Asus A52F Hard Drive Replacement, Hard Drive: step 5, image 3 of 3
    • Remove the four Phillips #0 screws holding the hard drive case to the laptop.
    • Lift the hard drive upwards by the two arms in order to remove the hard drive case from the laptop.
  6. Asus A52F Hard Drive Replacement: step 6, image 1 of 2 Asus A52F Hard Drive Replacement: step 6, image 2 of 2
    • Using a Phillips #0 screwdriver, remove the cage screws on the side of the hard drive.
  7. Asus A52F Hard Drive Replacement: step 7, image 1 of 2 Asus A52F Hard Drive Replacement: step 7, image 2 of 2
    • Next, slide the case off of the broken hard drive.
    • Slide the working hard drive into the case and screw it on.
3 other people completed this guide.
Roman Justice
255 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 29
All Time: 1,974
