Asus A52F RAM Replacement
  1. Asus A52F RAM Replacement, Battery: step 1, image 1 of 2 Asus A52F RAM Replacement, Battery: step 1, image 2 of 2
    • Place the laptop face down with the battery facing away from you.
    • Locate the two buttons next to the battery.
    • Slide the right slider to the unlocked (red) position.
  2. Asus A52F RAM Replacement: step 2, image 1 of 2 Asus A52F RAM Replacement: step 2, image 2 of 2
    • Hold the left button to the left.
    • Slide the battery with your other hand away from you and it should disconnect.
  3. Asus A52F RAM Replacement, Lower Case: step 3, image 1 of 3 Asus A52F RAM Replacement, Lower Case: step 3, image 2 of 3 Asus A52F RAM Replacement, Lower Case: step 3, image 3 of 3
    • Remove the five Phillips # 0 screws from the back panel.
    • Using your finger or a plastic spudger start to carefully pry up the back planel.
  4. Asus A52F RAM Replacement: step 4, image 1 of 2 Asus A52F RAM Replacement: step 4, image 2 of 2
    • Slide the back panel away and remove the panel.
  5. Asus A52F RAM Replacement, RAM: step 5, image 1 of 1
    • Gently push the metal retaining arms away from the center of the RAM module.
  6. Asus A52F RAM Replacement: step 6, image 1 of 3 Asus A52F RAM Replacement: step 6, image 2 of 3 Asus A52F RAM Replacement: step 6, image 3 of 3
    • The RAM should now be sticking up at a 30° angle.
    • Carefully grab the top edge of the RAM and gently pull it it out at it's angle.
  7. Asus A52F RAM Replacement: step 7, image 1 of 1
    • Repeat removal process for the RAM underneath.
  8. Asus A52F RAM Replacement: step 8, image 1 of 2 Asus A52F RAM Replacement: step 8, image 2 of 2
    • To insert new RAM line up notch in the connector and slide in at a 30° angle.
    • RAM only goes in one way!
    • Push straight down until the metal clips on both sides click into place
2 other people completed this guide.
Bradley Varnum
294 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 17
All Time: 913
