Asus A52F Screen Replacement
  1. Asus A52F Screen Replacement, Screen: step 1, image 1 of 2 Asus A52F Screen Replacement, Screen: step 1, image 2 of 2
    • Remove the six rubber pads around the border of the screen using a spudger.
  2. Asus A52F Screen Replacement: step 2, image 1 of 1
    • Remove the six screws using a Phillips #0 screwdriver.
  3. Asus A52F Screen Replacement: step 3, image 1 of 2 Asus A52F Screen Replacement: step 3, image 2 of 2
    • Separate the plastic bezel from the rest of the screen using an opening tool.
  4. Asus A52F Screen Replacement: step 4, image 1 of 2 Asus A52F Screen Replacement: step 4, image 2 of 2
    • Lift the metal bar on the top of the screen away from the device.
  5. Asus A52F Screen Replacement: step 5, image 1 of 3 Asus A52F Screen Replacement: step 5, image 2 of 3 Asus A52F Screen Replacement: step 5, image 3 of 3
    • Gently detach the wire to the left of the webcam.
  6. Asus A52F Screen Replacement: step 6, image 1 of 2 Asus A52F Screen Replacement: step 6, image 2 of 2
    • Carefully pull the screen toward you and lay it on the keyboard.
    • Peel the webcam wire off the back of the screen.
  7. Asus A52F Screen Replacement: step 7, image 1 of 3 Asus A52F Screen Replacement: step 7, image 2 of 3 Asus A52F Screen Replacement: step 7, image 3 of 3
    • Peel back the tape holding the screen cable in its socket.
    • Gently pull the tape and cable away from you to remove the cable from the socket.
    • The screen is now disconnected and can be removed.
Morgan Hays
348 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 1,354
