Asus A52F Wifi Card Replacement
  1. Asus A52F Wifi Card Replacement, Battery: step 1, image 1 of 2 Asus A52F Wifi Card Replacement, Battery: step 1, image 2 of 2
    • Place the laptop face down with the battery facing away from you.
    • Locate the two buttons next to the battery.
    • Slide the right slider to the unlocked (red) position.
  2. Asus A52F Wifi Card Replacement: step 2, image 1 of 2 Asus A52F Wifi Card Replacement: step 2, image 2 of 2
    • Hold the left button to the left.
    • Slide the battery with your other hand away from you and it should disconnect.
  3. Asus A52F Wifi Card Replacement, Lower Case: step 3, image 1 of 3 Asus A52F Wifi Card Replacement, Lower Case: step 3, image 2 of 3 Asus A52F Wifi Card Replacement, Lower Case: step 3, image 3 of 3
    • Remove the five Phillips # 0 screws from the back panel.
    • Using your finger or a plastic spudger start to carefully pry up the back planel.
  4. Asus A52F Wifi Card Replacement: step 4, image 1 of 2 Asus A52F Wifi Card Replacement: step 4, image 2 of 2
    • Slide the back panel away and remove the panel.
  5. Asus A52F Wifi Card Replacement, Wifi Card: step 5, image 1 of 2 Asus A52F Wifi Card Replacement, Wifi Card: step 5, image 2 of 2
    • First, find the Wi-Fi card
    • Move the protective flap back and use a Phillips size 0 screw driver to remove the two screws.
  6. Asus A52F Wifi Card Replacement: step 6, image 1 of 3 Asus A52F Wifi Card Replacement: step 6, image 2 of 3 Asus A52F Wifi Card Replacement: step 6, image 3 of 3
    • First remove both of the wires from the WiFi card.
    • Lift the WiFi card up and remove it.
Roman Justice
225 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 17
All Time: 1,796
