Asus A52F XE2 Lower Case Replacement
  1. Asus A52F XE2 Lower Case Replacement, Battery: step 1, image 1 of 2 Asus A52F XE2 Lower Case Replacement, Battery: step 1, image 2 of 2
    • Place the laptop face down with the battery facing away from you.
    • Locate the two buttons next to the battery.
    • Slide the right slider to the unlocked (red) position.
  2. Asus A52F XE2 Lower Case Replacement: step 2, image 1 of 2 Asus A52F XE2 Lower Case Replacement: step 2, image 2 of 2
    • Hold the left button to the left.
    • Slide the battery with your other hand away from you and it should disconnect.
  3. Asus A52F XE2 Lower Case Replacement, Lower Case: step 3, image 1 of 3 Asus A52F XE2 Lower Case Replacement, Lower Case: step 3, image 2 of 3 Asus A52F XE2 Lower Case Replacement, Lower Case: step 3, image 3 of 3
    • Remove the five Phillips # 0 screws from the back panel.
    • Using your finger or a plastic spudger start to carefully pry up the back planel.
  4. Asus A52F XE2 Lower Case Replacement: step 4, image 1 of 2 Asus A52F XE2 Lower Case Replacement: step 4, image 2 of 2
    • Slide the back panel away and remove the panel.
Michael Benson
149 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 9
All Time: 422
