Asus A53S Motherboard Replacement
  1. Asus A53S Motherboard Replacement, Motherboard: step 1, image 1 of 3 Asus A53S Motherboard Replacement, Motherboard: step 1, image 2 of 3 Asus A53S Motherboard Replacement, Motherboard: step 1, image 3 of 3
    • Power off your device and remove the battery before beginning this guide.
    • Flip the laptop so the underside is facing up.
    • Using a Phillips #01 screwdriver, unscrew the two 6 mm screws.
  2. Asus A53S Motherboard Replacement: step 2, image 1 of 2 Asus A53S Motherboard Replacement: step 2, image 2 of 2
    • Place a spudger under the white wire and pull it up gently, disconnecting it from the Wi-Fi card.
    • Use the same method on the black wire.
  3. Asus A53S Motherboard Replacement: step 3, image 1 of 3 Asus A53S Motherboard Replacement: step 3, image 2 of 3 Asus A53S Motherboard Replacement: step 3, image 3 of 3
    • Push the hard drive to the left and remove it.
  4. Asus A53S Motherboard Replacement: step 4, image 1 of 2 Asus A53S Motherboard Replacement: step 4, image 2 of 2
    • Using a Phillips #01 screwdriver, unscrew the fifteen 6 mm screws.
  5. Asus A53S Motherboard Replacement: step 5, image 1 of 2 Asus A53S Motherboard Replacement: step 5, image 2 of 2
    • Flip over the laptop and open it.
    • Using the spudger, insert the flat end into the notches at the top of the keyboard and slowly "pop" the keyboard up and out of the device.
  6. Asus A53S Motherboard Replacement: step 6, image 1 of 2 Asus A53S Motherboard Replacement: step 6, image 2 of 2
    • Using the flat end of the spudger, lift the black ZIF connector lock bar and disconnect the keyboard from the computer.
    • Remove the keyboard.
  7. Asus A53S Motherboard Replacement: step 7, image 1 of 2 Asus A53S Motherboard Replacement: step 7, image 2 of 2
    • Using the spudger, place the flat end under the black lock bar holding the power switch. Push the spudger up and to the left, disconnecting the power switch.
    • Use the same technique on the touchpad to disconnect it.
  8. Asus A53S Motherboard Replacement: step 8, image 1 of 2 Asus A53S Motherboard Replacement: step 8, image 2 of 2
    • Using a Phillips #01 screwdriver, unscrew the seven 6 mm screws.
  9. Asus A53S Motherboard Replacement: step 9, image 1 of 1
    • Gently pull out the optical drive.
  10. Asus A53S Motherboard Replacement: step 10, image 1 of 1
    • Flip the laptop back over so that the bottom is facing up.
    • Use a Phillips #01 screwdriver to unscrew the three 6 mm screws.
  11. Asus A53S Motherboard Replacement: step 11, image 1 of 2 Asus A53S Motherboard Replacement: step 11, image 2 of 2
    • Turn the laptop back over so that you can open it.
    • Gently separate the cover from the laptop by putting an opening tool between the cover and the lower part of the laptop.
  12. Asus A53S Motherboard Replacement: step 12, image 1 of 1
    • Remove the yellow tape.
  13. Asus A53S Motherboard Replacement: step 13, image 1 of 1
    • Using the flat end of a spudger, flip ZIF connector lock bar up, disconnecting the USB board from the mother board.
  14. Asus A53S Motherboard Replacement: step 14, image 1 of 2 Asus A53S Motherboard Replacement: step 14, image 2 of 2
    • Using the pointy end of a spudger, push upwards on the notches of the tan part of the LCD connector.
  15. Asus A53S Motherboard Replacement: step 15, image 1 of 2 Asus A53S Motherboard Replacement: step 15, image 2 of 2
    • Using the pointy end of a spudger, gently push upwards on the black part of the speaker connector.
  16. Asus A53S Motherboard Replacement: step 16, image 1 of 2 Asus A53S Motherboard Replacement: step 16, image 2 of 2
    • Using a Phillips #01 screwdriver, unscrew the five 6 mm screws at the indicated places.
    • Using a Phillips #01 screwdriver, unscrew the 5 mm screws.
    • All of these screws are indicated by a small white arrow.
  17. Asus A53S Motherboard Replacement: step 17, image 1 of 2 Asus A53S Motherboard Replacement: step 17, image 2 of 2
    • Gently lift the motherboard, removing it from the laptop shell.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 25
All Time: 736
