Asus A53S Wi-Fi Card Replacement
  1. Asus A53S Wi-Fi Card Replacement, Wi-Fi Card: step 1, image 1 of 3 Asus A53S Wi-Fi Card Replacement, Wi-Fi Card: step 1, image 2 of 3 Asus A53S Wi-Fi Card Replacement, Wi-Fi Card: step 1, image 3 of 3
    • Power off your device and remove the battery before beginning this guide.
    • Flip the laptop so the underside is facing up.
    • Using a Phillips #01 screwdriver, unscrew the two 6 mm screws at the indicated places.
    • Remove the back plate.
  2. Asus A53S Wi-Fi Card Replacement: step 2, image 1 of 2 Asus A53S Wi-Fi Card Replacement: step 2, image 2 of 2
    • Place a spudger under the white wire and pull it up gently, disconnecting it from the Wi-FI card.
    • Use the same method on the black wire.
  3. Asus A53S Wi-Fi Card Replacement: step 3, image 1 of 3 Asus A53S Wi-Fi Card Replacement: step 3, image 2 of 3 Asus A53S Wi-Fi Card Replacement: step 3, image 3 of 3
    • Using a Phillips #01 screwdriver, unscrew the 5 mm screw where indicated, allowing the Wi-Fi card to pop up.
    • Remove the Wi-Fi card.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 28
All Time: 491
