Asus A53U-ES21 Hard Drive Replacement
  1. Asus A53U-ES21 Hard Drive Replacement, Battery: step 1, image 1 of 2 Asus A53U-ES21 Hard Drive Replacement, Battery: step 1, image 2 of 2
    • Make sure the laptop is off.
    • Flip the laptop upside down so that the battery is facing you.
  2. Asus A53U-ES21 Hard Drive Replacement: step 2, image 1 of 2 Asus A53U-ES21 Hard Drive Replacement: step 2, image 2 of 2
    • Move the two sliders towards the outer edge of the laptop.
    • Pull the battery out with your left hand while holding the right slider.
  3. Asus A53U-ES21 Hard Drive Replacement, Hard Drive: step 3, image 1 of 2 Asus A53U-ES21 Hard Drive Replacement, Hard Drive: step 3, image 2 of 2
    • Remove the 5mm screw using a Phillips #1 screwdriver.
    • Use the iFixit opening tools to remove the hard drive panel.
  4. Asus A53U-ES21 Hard Drive Replacement: step 4, image 1 of 2 Asus A53U-ES21 Hard Drive Replacement: step 4, image 2 of 2
    • Pull upwards on the black ribbon on the end of the hard drive.
    • Pull the hard drive out from its socket and remove it from the device.
Chase Poirier
544 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 521
