Asus A53U-ES21 Heat Sink Replacement
  1. Asus A53U-ES21 Heat Sink Replacement, Battery: step 1, image 1 of 2 Asus A53U-ES21 Heat Sink Replacement, Battery: step 1, image 2 of 2
    • Make sure the laptop is off.
    • Flip the laptop upside down so that the battery is facing you.
  2. Asus A53U-ES21 Heat Sink Replacement: step 2, image 1 of 2 Asus A53U-ES21 Heat Sink Replacement: step 2, image 2 of 2
    • Move the two sliders towards the outer edge of the laptop.
    • Pull the battery out with your left hand while holding the right slider.
  3. Asus A53U-ES21 Heat Sink Replacement, Optical Drive: step 3, image 1 of 3 Asus A53U-ES21 Heat Sink Replacement, Optical Drive: step 3, image 2 of 3 Asus A53U-ES21 Heat Sink Replacement, Optical Drive: step 3, image 3 of 3
    • Remove the 5mm screw using a Phillips #1 screwdriver.
    • Use the iFixit opening tools to remove the RAM panel.
  4. Asus A53U-ES21 Heat Sink Replacement: step 4, image 1 of 3 Asus A53U-ES21 Heat Sink Replacement: step 4, image 2 of 3 Asus A53U-ES21 Heat Sink Replacement: step 4, image 3 of 3
    • Remove the 7mm screw using a Phillips #1 screwdriver.
    • Pull the optical drive out from the side of the laptop.
  5. Asus A53U-ES21 Heat Sink Replacement, Keyboard: step 5, image 1 of 3 Asus A53U-ES21 Heat Sink Replacement, Keyboard: step 5, image 2 of 3 Asus A53U-ES21 Heat Sink Replacement, Keyboard: step 5, image 3 of 3
    • Remove the RAM cover from the bottom of the keyboard.
    • Remove the 5mm screw keeping the panel in place using a Phillips #1 screwdriver.
    • Work the pry tool along the edge to finish removal.
    • Unscrew the two 7mm screws marked with an engraved "K" using a #1 Phillips screwdriver.
  6. Asus A53U-ES21 Heat Sink Replacement: step 6, image 1 of 3 Asus A53U-ES21 Heat Sink Replacement: step 6, image 2 of 3 Asus A53U-ES21 Heat Sink Replacement: step 6, image 3 of 3
    • Orient the computer so the keyboard is facing toward you with the screen at the top.
    • Find the three buttons to depress at top of the keyboard, set in the crack between the casing and the keyboard, highlighted here in red.
    • Use the pry tool to depress the buttons. The keyboard should pop out.
  7. Asus A53U-ES21 Heat Sink Replacement: step 7, image 1 of 3 Asus A53U-ES21 Heat Sink Replacement: step 7, image 2 of 3 Asus A53U-ES21 Heat Sink Replacement: step 7, image 3 of 3
    • Fold the keyboard out towards you. It should still be connected by a ribbon to the rest of the computer.
    • Gently use the opening tool to lift the black piece holding the ribbon down and remove the ribbon.
    • The black piece should cover the white line on the ribbon when it is replaced.
  8. Asus A53U-ES21 Heat Sink Replacement, Motherboard: step 8, image 1 of 1
    • Close the laptop and place it upside down.
    • Remove the twelve 7mm screws using a Phillips #1 screwdriver.
  9. Asus A53U-ES21 Heat Sink Replacement: step 9, image 1 of 1
    • Remove the two 2mm screws using a Phillips #1 screwdriver.
  10. Asus A53U-ES21 Heat Sink Replacement: step 10, image 1 of 2 Asus A53U-ES21 Heat Sink Replacement: step 10, image 2 of 2
    • Pull the connectors away from the wireless card using the plastic opening tools.
    • Pull the white connector from its socket in the RAM panel.
  11. Asus A53U-ES21 Heat Sink Replacement: step 11, image 1 of 1
    • Flip the laptop over again, open it, and unscrew the three 7mm screws using a Phillips #1 screwdriver.
  12. Asus A53U-ES21 Heat Sink Replacement: step 12, image 1 of 3 Asus A53U-ES21 Heat Sink Replacement: step 12, image 2 of 3 Asus A53U-ES21 Heat Sink Replacement: step 12, image 3 of 3
    • Gently pull the tan flap off of the cable using the plastic opening tool.
    • Push the tan piece towards the cable and release it using the plastic opening tool.
    • Pull the black flap off of its connector.
  13. Asus A53U-ES21 Heat Sink Replacement: step 13, image 1 of 2 Asus A53U-ES21 Heat Sink Replacement: step 13, image 2 of 2
    • Separate the front plate of the laptop from the back using the plastic opening tool.
  14. Asus A53U-ES21 Heat Sink Replacement: step 14, image 1 of 3 Asus A53U-ES21 Heat Sink Replacement: step 14, image 2 of 3 Asus A53U-ES21 Heat Sink Replacement: step 14, image 3 of 3
    • Remove the single 7mm screw from the motherboard using a Phillips #1 screwdriver.
    • Pull to two shown cables from their sockets using the plastic opening tools.
    • Gently remove the motherboard from the laptop.
  15. Asus A53U-ES21 Heat Sink Replacement, Heat Sink: step 15, image 1 of 1
    • To remove the heat sink, unscrew the four 7mm screws using a Phillips #1 screwdriver.
    • Remove the heatsink from the device.
Justin Ogihara
27,656 Reputation
52 Guides authored
EDU Team Member of EDU Team
Staff
7 Members
677 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 386
