Asus A53U-ES21 Keyboard Replacement
  1. Asus A53U-ES21 Keyboard Replacement, Battery: step 1, image 1 of 2 Asus A53U-ES21 Keyboard Replacement, Battery: step 1, image 2 of 2
    • Make sure the laptop is off.
    • Flip the laptop upside down so that the battery is facing you.
  2. Asus A53U-ES21 Keyboard Replacement: step 2, image 1 of 2 Asus A53U-ES21 Keyboard Replacement: step 2, image 2 of 2
    • Move the two sliders towards the outer edge of the laptop.
    • Pull the battery out with your left hand while holding the right slider.
  3. Asus A53U-ES21 Keyboard Replacement, Keyboard: step 3, image 1 of 3 Asus A53U-ES21 Keyboard Replacement, Keyboard: step 3, image 2 of 3 Asus A53U-ES21 Keyboard Replacement, Keyboard: step 3, image 3 of 3
    • Remove the RAM cover from the bottom of the keyboard.
    • Remove the 5mm screw keeping the panel in place using a Phillips #1 screwdriver.
    • Work the pry tool along the edge to finish removal.
    • Unscrew the two 7mm screws marked with an engraved "K" using a #1 Phillips screwdriver.
  4. Asus A53U-ES21 Keyboard Replacement: step 4, image 1 of 3 Asus A53U-ES21 Keyboard Replacement: step 4, image 2 of 3 Asus A53U-ES21 Keyboard Replacement: step 4, image 3 of 3
    • Orient the computer so the keyboard is facing toward you with the screen at the top.
    • Find the three buttons to depress at top of the keyboard, set in the crack between the casing and the keyboard, highlighted here in red.
    • Use the pry tool to depress the buttons. The keyboard should pop out.
  5. Asus A53U-ES21 Keyboard Replacement: step 5, image 1 of 3 Asus A53U-ES21 Keyboard Replacement: step 5, image 2 of 3 Asus A53U-ES21 Keyboard Replacement: step 5, image 3 of 3
    • Fold the keyboard out towards you. It should still be connected by a ribbon to the rest of the computer.
    • Gently use the opening tool to lift the black piece holding the ribbon down and remove the ribbon.
    • The black piece should cover the white line on the ribbon when it is replaced.
Mabel Trager
147 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 524
