Asus Chromebook C201PA-DS02-LG Keyboard Replacement
  1. Asus Chromebook C201PA-DS02-LG Keyboard Replacement, Keyboard: step 1, image 1 of 3 Asus Chromebook C201PA-DS02-LG Keyboard Replacement, Keyboard: step 1, image 2 of 3 Asus Chromebook C201PA-DS02-LG Keyboard Replacement, Keyboard: step 1, image 3 of 3
    • Use a metal spudger to pry off the two feet closest to the hinge of the laptop.
    • The feet are attached to the laptop by adhesives, therefore they may not stick as well after multiple removals.
  2. Asus Chromebook C201PA-DS02-LG Keyboard Replacement: step 2, image 1 of 2 Asus Chromebook C201PA-DS02-LG Keyboard Replacement: step 2, image 2 of 2
    • Use a Phillips #0 screwdriver to unscrew the six 5mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 6mm screws.
  3. Asus Chromebook C201PA-DS02-LG Keyboard Replacement: step 3, image 1 of 2 Asus Chromebook C201PA-DS02-LG Keyboard Replacement: step 3, image 2 of 2
    • Use a plastic opening tool to pry the keyboard off the edges of the computer.
    • The edges will make a popping noise.
  4. Asus Chromebook C201PA-DS02-LG Keyboard Replacement: step 4, image 1 of 3 Asus Chromebook C201PA-DS02-LG Keyboard Replacement: step 4, image 2 of 3 Asus Chromebook C201PA-DS02-LG Keyboard Replacement: step 4, image 3 of 3
    • Flip up the white bar that connects the thin white strip using a plastic opening tool.
    • Grab the thin white strip and pull straight back to remove the strip from the connector.
  5. Asus Chromebook C201PA-DS02-LG Keyboard Replacement: step 5, image 1 of 3 Asus Chromebook C201PA-DS02-LG Keyboard Replacement: step 5, image 2 of 3 Asus Chromebook C201PA-DS02-LG Keyboard Replacement: step 5, image 3 of 3
    • Use a plastic opening tool to lift the black bar above the wide black strip in the connector.
    • Grab the wide black strip and pull straight back to remove the strip from the connector.
    • Remove the keyboard by lifting it straight up.
Brittany M Won
577 Reputation
5 Guides authored
Cal Poly, Team S17-G4, Livingston Spring 2018 Member of Cal Poly, Team S17-G4, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G4
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 214
