Asus Chromebook C201PA-DS02-LG Screen Replacement
  1. Asus Chromebook C201PA-DS02-LG Screen Replacement, Keyboard: step 1, image 1 of 3 Asus Chromebook C201PA-DS02-LG Screen Replacement, Keyboard: step 1, image 2 of 3 Asus Chromebook C201PA-DS02-LG Screen Replacement, Keyboard: step 1, image 3 of 3
    • Use a metal spudger to pry off the two feet closest to the hinge of the laptop.
    • The feet are attached to the laptop by adhesives, therefore they may not stick as well after multiple removals.
  2. Asus Chromebook C201PA-DS02-LG Screen Replacement: step 2, image 1 of 2 Asus Chromebook C201PA-DS02-LG Screen Replacement: step 2, image 2 of 2
    • Use a Phillips #0 screwdriver to unscrew the six 5mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 6mm screws.
  3. Asus Chromebook C201PA-DS02-LG Screen Replacement: step 3, image 1 of 2 Asus Chromebook C201PA-DS02-LG Screen Replacement: step 3, image 2 of 2
    • Use a plastic opening tool to pry the keyboard off the edges of the computer.
    • The edges will make a popping noise.
  4. Asus Chromebook C201PA-DS02-LG Screen Replacement: step 4, image 1 of 3 Asus Chromebook C201PA-DS02-LG Screen Replacement: step 4, image 2 of 3 Asus Chromebook C201PA-DS02-LG Screen Replacement: step 4, image 3 of 3
    • Flip up the white bar that connects the thin white strip using a plastic opening tool.
    • Grab the thin white strip and pull straight back to remove the strip from the connector.
  5. Asus Chromebook C201PA-DS02-LG Screen Replacement: step 5, image 1 of 3 Asus Chromebook C201PA-DS02-LG Screen Replacement: step 5, image 2 of 3 Asus Chromebook C201PA-DS02-LG Screen Replacement: step 5, image 3 of 3
    • Use a plastic opening tool to lift the black bar above the wide black strip in the connector.
    • Grab the wide black strip and pull straight back to remove the strip from the connector.
    • Remove the keyboard by lifting it straight up.
  6. Asus Chromebook C201PA-DS02-LG Screen Replacement, Metal Plate: step 6, image 1 of 3 Asus Chromebook C201PA-DS02-LG Screen Replacement, Metal Plate: step 6, image 2 of 3 Asus Chromebook C201PA-DS02-LG Screen Replacement, Metal Plate: step 6, image 3 of 3
    • Unscrew the seven 4mm screws using a Phillips #0 screwdriver.
    • Wiggle the plate back and forth to loosen the adhesive under the plate.
    • The adhesive will not be the same after removal and more adhesive may be necessary upon reassembly.
    • Rotate the screwdriver in a counterclockwise direction to remove the screws.
    • Do not rest your arm or hand in the adhesive.
  7. Asus Chromebook C201PA-DS02-LG Screen Replacement, Screen: step 7, image 1 of 3 Asus Chromebook C201PA-DS02-LG Screen Replacement, Screen: step 7, image 2 of 3 Asus Chromebook C201PA-DS02-LG Screen Replacement, Screen: step 7, image 3 of 3
    • Unscrew the 4mm screws with a Phillips #0 screwdriver by rotating the screwdriver counterclockwise.
    • There is a screw that is hidden under the black tarped connection that connects the screen to the motherboard.
  8. Asus Chromebook C201PA-DS02-LG Screen Replacement: step 8, image 1 of 3 Asus Chromebook C201PA-DS02-LG Screen Replacement: step 8, image 2 of 3 Asus Chromebook C201PA-DS02-LG Screen Replacement: step 8, image 3 of 3
    Tool used on this step:
    Buy
    • Lift the tarp material straight up off the external output using tweezers. It is simply taped on.
  9. Asus Chromebook C201PA-DS02-LG Screen Replacement: step 9, image 1 of 3 Asus Chromebook C201PA-DS02-LG Screen Replacement: step 9, image 2 of 3 Asus Chromebook C201PA-DS02-LG Screen Replacement: step 9, image 3 of 3
    • Use a pair of tweezers to grip the tarped connector and lift vertically up. It may help to do this on each side of the attachment, rather than in one pull.
    • Lifting the tarped connector straight up may feel like you are breaking it, but this is normal.
  10. Asus Chromebook C201PA-DS02-LG Screen Replacement: step 10, image 1 of 3 Asus Chromebook C201PA-DS02-LG Screen Replacement: step 10, image 2 of 3 Asus Chromebook C201PA-DS02-LG Screen Replacement: step 10, image 3 of 3
    • Pop these two connections off by using tweezers to lift straight up.
  11. Asus Chromebook C201PA-DS02-LG Screen Replacement: step 11, image 1 of 1
    • Lift the screen up to fully remove.
Brittany M Won
577 Reputation
5 Guides authored
Cal Poly, Team S17-G4, Livingston Spring 2018 Member of Cal Poly, Team S17-G4, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G4
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 258
