Asus Chromebook C202SA-YS02 Camera Replacement
  1. Asus Chromebook C202SA-YS02 Camera Replacement, Bezel: step 1, image 1 of 1
    • Using a flat blade, remove the two screw covers on the front of the bezel. They are attached by adhesive, so you may have to dig at it a little bit.
  2. Asus Chromebook C202SA-YS02 Camera Replacement: step 2, image 1 of 1
    • Unscrew and remove the two Phillips #1 4.5 mm screws that are now visible.
  3. Asus Chromebook C202SA-YS02 Camera Replacement: step 3, image 1 of 1
    • Using the plastic opening tool, carefully pry off the bezel. It will come off entirely, so be careful not to break it.
  4. Asus Chromebook C202SA-YS02 Camera Replacement, Camera: step 4, image 1 of 1
    • Using the spudger, disconnect the cable from the camera. The camera will then pop out.
Beau Hansen
845 Reputation
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 764
