Asus Chromebook C202SA-YS02 Display Replacement
  1. Asus Chromebook C202SA-YS02 Display Replacement, Palm Rest: step 1, image 1 of 1
    • Turn the device over so the bottom is facing up.
    • Remove the ten Phillips #1 8.0 mm screws.
  2. Asus Chromebook C202SA-YS02 Display Replacement: step 2, image 1 of 2 Asus Chromebook C202SA-YS02 Display Replacement: step 2, image 2 of 2
    • Carefully use the plastic opening tool to pry the palm rest apart from the bottom cover. Start from one spot and systematically work your way around until the whole palm rest is detached.
  3. Asus Chromebook C202SA-YS02 Display Replacement: step 3, image 1 of 1
    • Disconnect the two cables that run from the keyboard to the motherboard and from the touch pad to the motherboard.
    • You may have to use a spudger to lift open the respective latches.
  4. Asus Chromebook C202SA-YS02 Display Replacement, Bezel: step 4, image 1 of 1
    • Using a flat blade, remove the two screw covers on the front of the bezel. They are attached by adhesive, so you may have to dig at it a little bit.
  5. Asus Chromebook C202SA-YS02 Display Replacement: step 5, image 1 of 1
    • Unscrew and remove the two Phillips #1 4.5 mm screws that are now visible.
  6. Asus Chromebook C202SA-YS02 Display Replacement: step 6, image 1 of 1
    • Using the plastic opening tool, carefully pry off the bezel. It will come off entirely, so be careful not to break it.
  7. Asus Chromebook C202SA-YS02 Display Replacement, Screen: step 7, image 1 of 3 Asus Chromebook C202SA-YS02 Display Replacement, Screen: step 7, image 2 of 3 Asus Chromebook C202SA-YS02 Display Replacement, Screen: step 7, image 3 of 3
    • Unscrew and remove the four screws holding the screen in place.
  8. Asus Chromebook C202SA-YS02 Display Replacement: step 8, image 1 of 1
    • Fold down screen and remove the screen connector band. You may have to use a small flat blade or a spudger, since the latch is very small.
  9. Asus Chromebook C202SA-YS02 Display Replacement, Daughterboard: step 9, image 1 of 1
    • Remove both Phillips #1 4.5 mm screws from the daughterboard.
  10. Asus Chromebook C202SA-YS02 Display Replacement: step 10, image 1 of 1
    • Gently remove the thin band from the daughterboard. You may have to use a thin blade or spudger to lift the silver clip to release the band.
  11. Asus Chromebook C202SA-YS02 Display Replacement, Display: step 11, image 1 of 1
    • Unscrew the one Phillips #1 3.5 mm screw located near the middle of the device.
  12. Asus Chromebook C202SA-YS02 Display Replacement: step 12, image 1 of 1
    • Remove the the storage chip from the motherboard. It should slide right out.
  13. Asus Chromebook C202SA-YS02 Display Replacement: step 13, image 1 of 2 Asus Chromebook C202SA-YS02 Display Replacement: step 13, image 2 of 2
    • Remove the four black and 1 gold (for a total of five) Phillips #1 3.0 mm screws from the display support. There are two screws on the right side and three on the left.
  14. Asus Chromebook C202SA-YS02 Display Replacement: step 14, image 1 of 1
    • Remove the connecting band from the motherboard. You may have to peel back some tape to be able to access the latch. A small thin blade or spudger might be useful to manipulate the small latch.
    • You can now remove the display. You may have to use the plastic opening tool to hold the motherboard up while you slide out the display.
Beau Hansen
845 Reputation
7 Guides authored
One Comment
Thank you for this guide. My daughter dropped her Chromebook last week and the display stopped working. I was able to fix it by reconnecting the screen cable to the mainboard.
Jonathan Fuerth - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 1,034
