Asus Chromebook C300M Key Replacement
  1. Asus Chromebook C300M Key Replacement, Bottom Panel: step 1, image 1 of 1
    • Flip the Chromebook over, bottom-side up.
  2. Asus Chromebook C300M Key Replacement: step 2, image 1 of 2 Asus Chromebook C300M Key Replacement: step 2, image 2 of 2
    • Remove the screws from the 11 spots using the aluminum driver with the J00 Philips head provided in iFixit toolkit.
    • Remove the eight 9.0mm Philips screws along the perimeter of the case.
    • Remove the three 6.0mm Philips screws from the center of the case.
    • Some versions may instead have six bigger screws (the four on the upper side of the image, close to the hinge, and two on the sides) and five smaller ones (four at the bottom of the image, where the laptop is thinner, and one in the center).
  3. Asus Chromebook C300M Key Replacement: step 3, image 1 of 1
    • Using a plastic opening tool, work around the Chromebook separating the plastic case at the seam.
  4. Asus Chromebook C300M Key Replacement: step 4, image 1 of 1
    • Open the Chromebook at hinges.
  5. Asus Chromebook C300M Key Replacement, Key: step 5, image 1 of 1
    • Detach the wide black keyboard cable from the switchboard.
  6. Asus Chromebook C300M Key Replacement: step 6, image 1 of 1
    • Unplug the white keyboard cable from switchboard.
  7. Asus Chromebook C300M Key Replacement: step 7, image 1 of 1
    • Remove the keyboard from the laptop body.
  8. Asus Chromebook C300M Key Replacement: step 8, image 1 of 1
    • Use the plastic opening tool to loosen a key of choice.
  9. Asus Chromebook C300M Key Replacement: step 9, image 1 of 1
    Tool used on this step:
    Buy
    • Removed the loosened key with the tweezers.
6 other people completed this guide.
Jake Van Loon
1,010 Reputation
3 Guides authored
One Comment
hello, i have a asus c300 my problem is when i open it i have get it just right to see picture .is it my video cable?
clint murchison - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 9
All Time: 5,181
