Asus Chromebook C300M USB Port Replacement
  1. Asus Chromebook C300M USB Port Replacement, USB Port: step 1, image 1 of 2 Asus Chromebook C300M USB Port Replacement, USB Port: step 1, image 2 of 2
    • Flip the chromebook on its front.
    • Remove the screws on the back using the Phillips #1 screwdriver.
    • Remove the six 8mm screws.
    • Remove the five 5mm screws.
  2. Asus Chromebook C300M USB Port Replacement: step 2, image 1 of 1
    • Separate the plastic case from the keyboard at the seam using a plastic opening tool.
  3. Asus Chromebook C300M USB Port Replacement: step 3, image 1 of 2 Asus Chromebook C300M USB Port Replacement: step 3, image 2 of 2
    • Fully separate the plastic case from the keyboard by lifting it upward.
  4. Asus Chromebook C300M USB Port Replacement: step 4, image 1 of 2 Asus Chromebook C300M USB Port Replacement: step 4, image 2 of 2
    • The small and wide ribbon cables connect the keyboard to the motherboard.
    • Disconnect the small ribbon cable by lifting the flap and sliding it out of the motherboard input toward the battery using a spudger.
    • Disconnect the wide ribbon cable by lifting the flap and sliding it out of the motherboard input toward the battery using a spudger.
  5. Asus Chromebook C300M USB Port Replacement: step 5, image 1 of 2 Asus Chromebook C300M USB Port Replacement: step 5, image 2 of 2
    • Disconnect the USB port in the top right corner from the motherboard.
    • Unplug the the wide ribbon cable using spudger.
  6. Asus Chromebook C300M USB Port Replacement: step 6, image 1 of 2 Asus Chromebook C300M USB Port Replacement: step 6, image 2 of 2
    • Remove the single 3mm screw on the left and bottom side of the USB Port using the Phillips #1 screwdriver.
    • Remove the three 5mm screws on the upper part of the USB port with the same screwdriver.
    • Lift the edge of the white casing. Remove the USB Port by pulling it toward the bottom of the laptop.
2 other people completed this guide.
Rachel Cadle
259 Reputation
2 Guides authored
IUPUI, Team S3-G2, Harley Spring 2019 Member of IUPUI, Team S3-G2, Harley Spring 2019
IUPUI-HARLEY-S19S3G2
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 14
All Time: 752
