Asus Chromebook C300MA-DB01 Battery Replacement
  1. Asus Chromebook C300MA-DB01 Battery Replacement, Back Cover: step 1, image 1 of 1
    • Place device bottom-side up.
  2. Asus Chromebook C300MA-DB01 Battery Replacement: step 2, image 1 of 1
    • Remove the three 6.0 mm Philips screws from the center of the case with the #2 screwdriver bit.
    • Remove the eight 9.0 mm Philips screws along the perimeter of the case with the #2 screwdriver bit.
  3. Asus Chromebook C300MA-DB01 Battery Replacement: step 3, image 1 of 1
    • Using a plastic opening tool, separate the bottom case at the seam.
    • Prying open a laptop requires a lot of force but use caution so as to avoid breaking the fragile connectors.
  4. Asus Chromebook C300MA-DB01 Battery Replacement: step 4, image 1 of 2 Asus Chromebook C300MA-DB01 Battery Replacement: step 4, image 2 of 2
    • Lift the keyboard panel away from the components at its hinges, which are located at the back of the laptop.
  5. Asus Chromebook C300MA-DB01 Battery Replacement, Battery: step 5, image 1 of 1
    • Remove the six 6.0mm Philips screws, using the 64 bit driver from around the battery.
  6. Asus Chromebook C300MA-DB01 Battery Replacement: step 6, image 1 of 1
    • Unplug the wire using the plastic opening tool that connects the battery with the board.
  7. Asus Chromebook C300MA-DB01 Battery Replacement: step 7, image 1 of 1
    • Lift the battery out of the laptop
wyatt boyatt
541 Reputation
5 Guides authored
USF Tampa, Team S4-G3, Eyestone Fall 2017 Member of USF Tampa, Team S4-G3, Eyestone Fall 2017
USFT-EYESTONE-F17S4G3
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 2,269
