Asus Chromebook C300MA-EDU Keyboard Replacement
  1. Asus Chromebook C300MA-EDU Keyboard Replacement, Keyboard: step 1, image 1 of 2 Asus Chromebook C300MA-EDU Keyboard Replacement, Keyboard: step 1, image 2 of 2
    • Flip the Chromebook onto its back, where there are eleven screws.
    • There are two variations of screws on the back panel:
    • Six 8.7mm screws.
    • Five 6.4mm screws.
    • Using your screwdriver with the J00 Phillips Head tip, remove the screws by turning them counter clockwise.
  2. Asus Chromebook C300MA-EDU Keyboard Replacement: step 2, image 1 of 2 Asus Chromebook C300MA-EDU Keyboard Replacement: step 2, image 2 of 2
    • Once the screws are removed, flip the Chromebook back over.
    • Gently remove the keyboard by starting to lift up on one corner with a plastic opening tool.
    • Follow around the brim of the keyboard until it pops off.
  3. Asus Chromebook C300MA-EDU Keyboard Replacement: step 3, image 1 of 3 Asus Chromebook C300MA-EDU Keyboard Replacement: step 3, image 2 of 3 Asus Chromebook C300MA-EDU Keyboard Replacement: step 3, image 3 of 3
    • Once you remove the keyboard, it will be connected to the CPU with two tabbed connections.
    • Release the connections from the tabs gently by flipping the white flaps up until disconnected.
    • You can now pull the ribbons out from the board and remove the keyboard.
Christopher Hart
501 Reputation
5 Guides authored
USF Tampa, Team S2-G3, Nance Fall 2017 Member of USF Tampa, Team S2-G3, Nance Fall 2017
USFT-NANCE-F17S2G3
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 692
