Asus Chromebook C300MA-EDU Speaker Replacement
  1. Asus Chromebook C300MA-EDU Speaker Replacement, Keyboard: step 1, image 1 of 2 Asus Chromebook C300MA-EDU Speaker Replacement, Keyboard: step 1, image 2 of 2
    • Flip the Chromebook onto its back, where there are eleven screws.
    • There are two variations of screws on the back panel:
    • Six 8.7mm screws.
    • Five 6.4mm screws.
    • Using your screwdriver with the J00 Phillips Head tip, remove the screws by turning them counter clockwise.
  2. Asus Chromebook C300MA-EDU Speaker Replacement: step 2, image 1 of 2 Asus Chromebook C300MA-EDU Speaker Replacement: step 2, image 2 of 2
    • Once the screws are removed, flip the Chromebook back over.
    • Gently remove the keyboard by starting to lift up on one corner with a plastic opening tool.
    • Follow around the brim of the keyboard until it pops off.
  3. Asus Chromebook C300MA-EDU Speaker Replacement: step 3, image 1 of 3 Asus Chromebook C300MA-EDU Speaker Replacement: step 3, image 2 of 3 Asus Chromebook C300MA-EDU Speaker Replacement: step 3, image 3 of 3
    • Once you remove the keyboard, it will be connected to the CPU with two tabbed connections.
    • Release the connections from the tabs gently by flipping the white flaps up until disconnected.
    • You can now pull the ribbons out from the board and remove the keyboard.
  4. Asus Chromebook C300MA-EDU Speaker Replacement, Battery: step 4, image 1 of 3 Asus Chromebook C300MA-EDU Speaker Replacement, Battery: step 4, image 2 of 3 Asus Chromebook C300MA-EDU Speaker Replacement, Battery: step 4, image 3 of 3
    • Once the keyboard is removed, the battery is located on the bottom portion of the shell.
    • The battery is held in with six 6.5mm screws on opposing sides.
  5. Asus Chromebook C300MA-EDU Speaker Replacement: step 5, image 1 of 2 Asus Chromebook C300MA-EDU Speaker Replacement: step 5, image 2 of 2
    • The battery is now held in with a tabbed connection to the CPU on the left side of the board. On the tabbed connection, there is a silver plate.
    • Gently push on the silver plate towards the screen until the plastic connection is free.
    • The tabbed connection should now slide out backwards.
  6. Asus Chromebook C300MA-EDU Speaker Replacement: step 6, image 1 of 2 Asus Chromebook C300MA-EDU Speaker Replacement: step 6, image 2 of 2
    • At this point, using the plastic removal tool, lift the battery out of the shell.
  7. Asus Chromebook C300MA-EDU Speaker Replacement, Speaker: step 7, image 1 of 2 Asus Chromebook C300MA-EDU Speaker Replacement, Speaker: step 7, image 2 of 2
    • The speakers are connected to the CPU via a tabbed connection.
    • Using a smaller plastic spudger, gently pull backwards on the plastic clip until it comes loose.
  8. Asus Chromebook C300MA-EDU Speaker Replacement: step 8, image 1 of 3 Asus Chromebook C300MA-EDU Speaker Replacement: step 8, image 2 of 3 Asus Chromebook C300MA-EDU Speaker Replacement: step 8, image 3 of 3
    • Next, the speaker is incorporated into two plastic clips which are in the shell of the Chromebook.
    • Using a smaller plastic spudger, gently pull upward on the plastic clips from the outer edge of the speaker unit.
  9. Asus Chromebook C300MA-EDU Speaker Replacement: step 9, image 1 of 2 Asus Chromebook C300MA-EDU Speaker Replacement: step 9, image 2 of 2
    • After taking off the speaker unit from both sides, remove the tape holding down the central wiring in the middle of the Chromebook’s shell.
    • Using a plastic opening tool or spudger, slide the tool underneath a corner of tape and run the tool until the tape is removed.
  10. Asus Chromebook C300MA-EDU Speaker Replacement: step 10, image 1 of 2 Asus Chromebook C300MA-EDU Speaker Replacement: step 10, image 2 of 2
    • Gently slide the wire out from its casing.
    • The speaker is now disconnected safely.
Christopher Hart
501 Reputation
5 Guides authored
USF Tampa, Team S2-G3, Nance Fall 2017 Member of USF Tampa, Team S2-G3, Nance Fall 2017
USFT-NANCE-F17S2G3
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 183
