Asus Chromebook C300SA-DS02 LED Screen Replacement
  1. Asus Chromebook C300SA-DS02 LED Screen Replacement, Keyboard: step 1, image 1 of 2 Asus Chromebook C300SA-DS02 LED Screen Replacement, Keyboard: step 1, image 2 of 2
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Remove the three 6.0mm Phillips #0 screws.
  2. Asus Chromebook C300SA-DS02 LED Screen Replacement: step 2, image 1 of 3 Asus Chromebook C300SA-DS02 LED Screen Replacement: step 2, image 2 of 3 Asus Chromebook C300SA-DS02 LED Screen Replacement: step 2, image 3 of 3
    • Open the laptop.
    • Using an iFixit opening tool, pry along the edges of the keyboard.
    • Lift the keyboard and slide it gently towards you.
    • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
  3. Asus Chromebook C300SA-DS02 LED Screen Replacement: step 3, image 1 of 3 Asus Chromebook C300SA-DS02 LED Screen Replacement: step 3, image 2 of 3 Asus Chromebook C300SA-DS02 LED Screen Replacement: step 3, image 3 of 3
    • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
  4. Asus Chromebook C300SA-DS02 LED Screen Replacement: step 4, image 1 of 1
    • Remove the keyboard from the laptop.
  5. Asus Chromebook C300SA-DS02 LED Screen Replacement, Battery: step 5, image 1 of 2 Asus Chromebook C300SA-DS02 LED Screen Replacement, Battery: step 5, image 2 of 2
    • Remove the six 5.6mm Phillips #0 screws around the battery.
  6. Asus Chromebook C300SA-DS02 LED Screen Replacement: step 6, image 1 of 2 Asus Chromebook C300SA-DS02 LED Screen Replacement: step 6, image 2 of 2
    • Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
  7. Asus Chromebook C300SA-DS02 LED Screen Replacement: step 7, image 1 of 1
    • Lift the battery out of the laptop.
  8. Asus Chromebook C300SA-DS02 LED Screen Replacement, LED Screen: step 8, image 1 of 2 Asus Chromebook C300SA-DS02 LED Screen Replacement, LED Screen: step 8, image 2 of 2
    • Unplug the black and white cable from the motherboard.
    • These two wires connect to the antenna within the display assembly. The white cable is longer and connects to the bottom import.
  9. Asus Chromebook C300SA-DS02 LED Screen Replacement: step 9, image 1 of 1
    • Peel back the tape covering the plug.
    • Slide the cable towards the screen and out of the input.
  10. Asus Chromebook C300SA-DS02 LED Screen Replacement: step 10, image 1 of 1
    • Unscrew the 6 screws (5 millimeter) on the top right and left.
  11. Asus Chromebook C300SA-DS02 LED Screen Replacement: step 11, image 1 of 1
    • Gently lift the screen up and away from the laptop.
  12. Asus Chromebook C300SA-DS02 LED Screen Replacement: step 12, image 1 of 1
    • Pry off the face panel on the screen using the blue prying tool.
  13. Asus Chromebook C300SA-DS02 LED Screen Replacement: step 13, image 1 of 1
    • Remove the four 2mm Phillips #0 screws from the four corners of the screen.
  14. Asus Chromebook C300SA-DS02 LED Screen Replacement: step 14, image 1 of 2 Asus Chromebook C300SA-DS02 LED Screen Replacement: step 14, image 2 of 2
    • Gently lift screen
    • Peel back the adhesive covering the cable.
    • Remove the cable to free the screen.
Celina Monteiro
224 Reputation
2 Guides authored
One Comment
I used this honestly I broke the screen and some of the wires in the screen are severed. Now I know for sure where the wires go and how to deconstruct it. Thank you so much!
Glorybringers Child - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 713
