Asus Chromebook C523N Back Cover Replacement
  1. Asus Chromebook C523N Back Cover Replacement, Back Cover: step 1, image 1 of 2 Asus Chromebook C523N Back Cover Replacement, Back Cover: step 1, image 2 of 2
    • Remove the four 0.5mm JIS #00 screws from the bottom edge of the Chromebook and one in the center.
    • Remove the six 1.7mm JIS #00 screws from the sides and top edge of the Chromebook.
  2. Asus Chromebook C523N Back Cover Replacement: step 2, image 1 of 2 Asus Chromebook C523N Back Cover Replacement: step 2, image 2 of 2
    • Using a spudger, lift the top left base pad and remove it to reveal a final screw underneath.
    • Remove the one 0.5mm JIS #00 screw underneath the base pad.
  3. Asus Chromebook C523N Back Cover Replacement: step 3, image 1 of 2 Asus Chromebook C523N Back Cover Replacement: step 3, image 2 of 2
    • Use an opening tool to gently pry the base enclosure up and remove from the laptop.
3 other people completed this guide.
0 Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 32
All Time: 3,186
