Introduction
If keys on the keyboard stick or are unresponsive when pressed for the Asus Chromebook C523N, use this guide to replace your keyboard. Before starting this guide, make certain that the Chromebook is not connected to power and is powered off.
Remove the four 0.5mm JIS #00 screws from the bottom edge of the Chromebook and one in the center.
Remove the six 1.7mm JIS #00 screws from the sides and top edge of the Chromebook.
Tool used on this step:Tweezers$4.99
Using the nylon tipped tweezers, gently pry the black and white wires from the wireless card and lift.
To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small locking flap.
Gently disconnect the battery cable from the motherboard.
Using tweezers, gently pry the black and white wires from the wireless card and lift.
2 other people completed this guide.
3 Comments
Great walk through. I used this to replace a keyboard on a C423N ASUS. Everything but the track pad connector on the mother board and three screws instead of 2 on the screen hinges is the same.
how to replace ssd in motherbord
