Asus Chromebook C523N Motherboard Replacement
  1. Asus Chromebook C523N Motherboard Replacement, Back Cover: step 1, image 1 of 2 Asus Chromebook C523N Motherboard Replacement, Back Cover: step 1, image 2 of 2
    • Remove the four 0.5mm JIS #00 screws from the bottom edge of the Chromebook and one in the center.
    • Remove the six 1.7mm JIS #00 screws from the sides and top edge of the Chromebook.
  2. Asus Chromebook C523N Motherboard Replacement: step 2, image 1 of 2 Asus Chromebook C523N Motherboard Replacement: step 2, image 2 of 2
    • Using a spudger, lift the top left base pad and remove it to reveal a final screw underneath.
    • Remove the one 0.5mm JIS #00 screw underneath the base pad.
  3. Asus Chromebook C523N Motherboard Replacement: step 3, image 1 of 2 Asus Chromebook C523N Motherboard Replacement: step 3, image 2 of 2
    • Use an opening tool to gently pry the base enclosure up and remove from the laptop.
  4. Asus Chromebook C523N Motherboard Replacement, Battery: step 4, image 1 of 3 Asus Chromebook C523N Motherboard Replacement, Battery: step 4, image 2 of 3 Asus Chromebook C523N Motherboard Replacement, Battery: step 4, image 3 of 3
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small locking flap.
    • Gently disconnect the battery cable from the motherboard.
  5. Asus Chromebook C523N Motherboard Replacement: step 5, image 1 of 2 Asus Chromebook C523N Motherboard Replacement: step 5, image 2 of 2
    • Remove six 1.4 mm JIS #00 screws from the battery.
  6. Asus Chromebook C523N Motherboard Replacement: step 6, image 1 of 1
    • Remove the battery from the laptop.
  7. Asus Chromebook C523N Motherboard Replacement, Motherboard: step 7, image 1 of 3 Asus Chromebook C523N Motherboard Replacement, Motherboard: step 7, image 2 of 3 Asus Chromebook C523N Motherboard Replacement, Motherboard: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • Using tweezers, gently pry the black and white wires from the wireless card and lift.
  8. Asus Chromebook C523N Motherboard Replacement: step 8, image 1 of 3 Asus Chromebook C523N Motherboard Replacement: step 8, image 2 of 3 Asus Chromebook C523N Motherboard Replacement: step 8, image 3 of 3
    • Gently pull the trackpad cable from the connector, located next to the wireless card.
  9. Asus Chromebook C523N Motherboard Replacement: step 9, image 1 of 3 Asus Chromebook C523N Motherboard Replacement: step 9, image 2 of 3 Asus Chromebook C523N Motherboard Replacement: step 9, image 3 of 3
    • Using a spudger, disconnect the two side-by-side ribbon cables from their connectors, pushing in the direction of the ribbons (toward the left side of the Chromebook).
  10. Asus Chromebook C523N Motherboard Replacement: step 10, image 1 of 2 Asus Chromebook C523N Motherboard Replacement: step 10, image 2 of 2
    • Disconnect the thick blue ribbon cable from the connector by pulling it away from the motherboard.
  11. Asus Chromebook C523N Motherboard Replacement: step 11, image 1 of 3 Asus Chromebook C523N Motherboard Replacement: step 11, image 2 of 3 Asus Chromebook C523N Motherboard Replacement: step 11, image 3 of 3
    • Remove the 0.4mm JIS #0 screws from the heat sink in the center of the motherboard.
    • Lift and remove the heat sink.
  12. Asus Chromebook C523N Motherboard Replacement: step 12, image 1 of 3 Asus Chromebook C523N Motherboard Replacement: step 12, image 2 of 3 Asus Chromebook C523N Motherboard Replacement: step 12, image 3 of 3
    • Gripping the thin white ribbon cable, gently pull it away from the motherboard to disconnect.
  13. Asus Chromebook C523N Motherboard Replacement: step 13, image 1 of 2 Asus Chromebook C523N Motherboard Replacement: step 13, image 2 of 2
    • Disconnect the thick black connector by gently pulling it up, away from the motherboard.
  14. Asus Chromebook C523N Motherboard Replacement: step 14, image 1 of 2 Asus Chromebook C523N Motherboard Replacement: step 14, image 2 of 2
    • Remove the two 0.4mm JIS #00 screws at the bottom of the hinge (closest to the motherboard).
    • Using an opening tool, pry the hinge upward.
  15. Asus Chromebook C523N Motherboard Replacement: step 15, image 1 of 2 Asus Chromebook C523N Motherboard Replacement: step 15, image 2 of 2
    • Remove the two 0.4 mm JIS #00 screws from the motherboard.
    • Gently lift and remove the motherboard.
4 other people completed this guide.
2 Comments
Hi!
I assembled the motherboard but it isn't working. There is no power light. How to validate that the motherboard is functioning?
If I just connect power stream to its USBC power port the LED should be lighting?
mmm - Reply
I was following this guide and I found there were actually four screws holding the MB down. The red/blue/white/black speaker cable must also be disconnected to get the board out entirely.
Jaret Meier - Reply
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 47
All Time: 3,652
