Asus Chromebook C523N Speaker Replacement
Aaron Hogan
Aaron Hogan and 5 other contributors
Last updated on May 7, 2024
10 - 15 minutes
Easy
Introduction
Go to step 1
If sound is dull or nonexistent from the Asus Chromebook C523N, use this guide to remove and replace your speakers.
Before using this guide, check the speaker for blockage that may be interfering with the sound. Usually, dust and debris can be cleared by a small dust blower. Make sure to check that the volume is not muted to confirm it needs replacing.
To begin this guide, check that the Chromebook’s power is off and it’s disconnected from any power source.
Tools
Show more…
  1. Asus Chromebook C523N Speaker Replacement, Back Cover: step 1, image 1 of 2 Asus Chromebook C523N Speaker Replacement, Back Cover: step 1, image 2 of 2
    • Remove the four 0.5mm JIS #00 screws from the bottom edge of the Chromebook and one in the center.
    • Remove the six 1.7mm JIS #00 screws from the sides and top edge of the Chromebook.
  2. Asus Chromebook C523N Speaker Replacement: step 2, image 1 of 2 Asus Chromebook C523N Speaker Replacement: step 2, image 2 of 2
    • Using a spudger, lift the top left base pad and remove it to reveal a final screw underneath.
    • Remove the one 0.5mm JIS #00 screw underneath the base pad.
  3. Asus Chromebook C523N Speaker Replacement: step 3, image 1 of 2 Asus Chromebook C523N Speaker Replacement: step 3, image 2 of 2
    • Use an opening tool to gently pry the base enclosure up and remove from the laptop.
  4. Asus Chromebook C523N Speaker Replacement, Speaker: step 4, image 1 of 3 Asus Chromebook C523N Speaker Replacement, Speaker: step 4, image 2 of 3 Asus Chromebook C523N Speaker Replacement, Speaker: step 4, image 3 of 3
    Tool used on this step:
    • Using the nylon tipped tweezers, gently pry the black and white wires from the wireless card and lift.
  5. Asus Chromebook C523N Speaker Replacement: step 5, image 1 of 3 Asus Chromebook C523N Speaker Replacement: step 5, image 2 of 3 Asus Chromebook C523N Speaker Replacement: step 5, image 3 of 3
    • Use a spudger to pry the small tangle of black, red, white, and blue wires from the audio connector, pushing the wires back toward the speaker.
  6. Asus Chromebook C523N Speaker Replacement: step 6, image 1 of 2 Asus Chromebook C523N Speaker Replacement: step 6, image 2 of 2
    • Use a spudger to pry the black wire from the audio connector, pushing the wires back toward the left speaker.
  7. Asus Chromebook C523N Speaker Replacement: step 7, image 1 of 1
    • Gently grab both speakers and lift them from the Chromebook to remove.
2 other people completed this guide.
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 5
All Time: 668
