Asus Eee PC 1000HE Keyboard Replacement
  1. Asus Eee PC 1000HE Keyboard Replacement, Battery: step 1, image 1 of 1
    • Lay the laptop down with the bottom facing upwards.
    • Locate the two battery lock slide tabs.
  2. Asus Eee PC 1000HE Keyboard Replacement: step 2, image 1 of 2 Asus Eee PC 1000HE Keyboard Replacement: step 2, image 2 of 2
    • Slide the tabs outward to unlock the battery.
    • The right tab will remain in the unlocked position while the left tab must be held.
    • While holding the left tab outward, slide the battery away from you to remove it.
  3. Asus Eee PC 1000HE Keyboard Replacement, Keyboard: step 3, image 1 of 3 Asus Eee PC 1000HE Keyboard Replacement, Keyboard: step 3, image 2 of 3 Asus Eee PC 1000HE Keyboard Replacement, Keyboard: step 3, image 3 of 3
    • The keyboard will still be attached to the body of the netbook at the conclusion of this step through a ribbon cable located at the bottom edge of the keyboard. Improper removal may result in damage to your device.
    • Identify the four connection points holding the top of the keyboard to the main body of the netbook. To remove the keyboard, use the spudger to unhook the keyboard upwards at these points.
    • The keyboard will become more disconnected as you use the spudger at each connection point.
  4. Asus Eee PC 1000HE Keyboard Replacement: step 4, image 1 of 3 Asus Eee PC 1000HE Keyboard Replacement: step 4, image 2 of 3 Asus Eee PC 1000HE Keyboard Replacement: step 4, image 3 of 3
    • Flip the keyboard over by pulling the top edge of the keyboard away from the netbook body, using the bottom edge as a hinge point.
    • Locate the opaque strip, or ribbon cable, connecting the back of the keyboard to the hardware of the netbook.
    • To disconnect the ribbon cable, use a plastic opening tool to pull each side of the black plastic strip, located below the ribbon cable, away from the ribbon cable.
    • The black strip will disconnect completely from the ribbon cable. The keyboard will then be detached from the netbook's body and can be safely removed.
2 other people completed this guide.
Mike Glenn
1,026 Reputation
8 Guides authored
Clemson, Team 6-2, Benson Spring 2016 Member of Clemson, Team 6-2, Benson Spring 2016
CLEM-BENSON-S16S6G2
4 Members
18 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 12
All Time: 1,267
