Asus Eee PC 1005HA Screen Replacement
  1. Asus Eee PC 1005HA Screen Replacement, Battery: step 1, image 1 of 1
    • Lay the laptop upside down.
    • Locate the two battery lock tabs.
  2. Asus Eee PC 1005HA Screen Replacement: step 2, image 1 of 3 Asus Eee PC 1005HA Screen Replacement: step 2, image 2 of 3 Asus Eee PC 1005HA Screen Replacement: step 2, image 3 of 3
    • Slide the tabs outward to unlock the battery.
    • The left tab will remain unlocked, while the right tab must be held.
    • Holding the right tab open, slide the battery out of the laptop.
  3. Asus Eee PC 1005HA Screen Replacement, Screen: step 3, image 1 of 3 Asus Eee PC 1005HA Screen Replacement, Screen: step 3, image 2 of 3 Asus Eee PC 1005HA Screen Replacement, Screen: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Using tweezers, remove the six screw covers on the screen bezel.
    • Remove the six 4.6 mm screws from the bezel.
  4. Asus Eee PC 1005HA Screen Replacement: step 4, image 1 of 1
    • Use a plastic opening tool to disengage the plastic clips that secure the screen bezel to the display.
    • Carefully remove the bezel from the display.
  5. Asus Eee PC 1005HA Screen Replacement: step 5, image 1 of 3 Asus Eee PC 1005HA Screen Replacement: step 5, image 2 of 3 Asus Eee PC 1005HA Screen Replacement: step 5, image 3 of 3
    • Remove the four 3.6 mm screws securing the screen.
    • Slowly lift the screen up from the rest of the laptop.
    • The screen is still attached to the laptop by a set of cables. Be careful not to damage them while removing the screen.
  6. Asus Eee PC 1005HA Screen Replacement: step 6, image 1 of 2 Asus Eee PC 1005HA Screen Replacement: step 6, image 2 of 2
    • Remove the plastic tape securing the display cables to the back of the screen.
    • Slide the display cable connector out its socket on the back of the screen.
  7. Asus Eee PC 1005HA Screen Replacement: step 7, image 1 of 2 Asus Eee PC 1005HA Screen Replacement: step 7, image 2 of 2
    • Remove the four 3.1 mm housing screws on the sides of the display housing frame
    • Remove the housing frame.
13 other people completed this guide.
Mitchell Cesare
802 Reputation
4 Guides authored
Cal Poly, Team 11-22, Maness Winter 2012 Member of Cal Poly, Team 11-22, Maness Winter 2012
CPSU-MANESS-W12S11G22
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 21
All Time: 21,626
