Asus Eee PC 1005PEB RAM Replacement
  1. Asus Eee PC 1005PEB RAM Replacement, RAM: step 1, image 1 of 2 Asus Eee PC 1005PEB RAM Replacement, RAM: step 1, image 2 of 2
    • Start by having the laptop upside down on a hard flat surface.
    • Find and unscrew the 6.65 mm Phillips #1 screw.
    • The screw will not detach from the RAM cover.
  2. Asus Eee PC 1005PEB RAM Replacement: step 2, image 1 of 2 Asus Eee PC 1005PEB RAM Replacement: step 2, image 2 of 2
    • Carefully remove the cover by lifting it with your fingers.
    • Make sure that you do not pull the cover to quickly or too hard as this could damage the plastic pins that hold the cover on.
  3. Asus Eee PC 1005PEB RAM Replacement: step 3, image 1 of 2 Asus Eee PC 1005PEB RAM Replacement: step 3, image 2 of 2
    • Identify the pins on both sides of the RAM.
    • Using both hands, pull the pins apart from each other to release the RAM.
    • The RAM will "pop" up on its own after the pins are pressed.
  4. Asus Eee PC 1005PEB RAM Replacement: step 4, image 1 of 1
    • Grab the RAM stick with two fingers and gently pull it out of its slot.
Aaron Arenas
751 Reputation
5 Guides authored
Cal Poly, Team 13-32, Maness Spring 2014 Member of Cal Poly, Team 13-32, Maness Spring 2014
CPSU-MANESS-S14S13G32
5 Members
5 Guides authored
1 Guide Comment
Everything I've read says you can only upgrade from the 1gb ram to a 2gig. Here's what I just installed: http://amzn.to/2x0flty and so far its working great...I notice a difference in speed, although this thing is still slow.
Dan Fowler - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 18
All Time: 1,146
