Asus Eee PC 1008ha Screen Replacement
  1. Asus Eee PC 1008ha Screen Replacement, Battery: step 1, image 1 of 1
    • Using the plastic opening tool, carefully pry the top panel from the base.
  2. Asus Eee PC 1008ha Screen Replacement: step 2, image 1 of 3 Asus Eee PC 1008ha Screen Replacement: step 2, image 2 of 3 Asus Eee PC 1008ha Screen Replacement: step 2, image 3 of 3
    • Lift the side of the keyboard.
    • Disconnect the attached ribbon located underneath the keyboard.
    • Place your index finger in the hole on the right side of the keyboard tray and lift the tray.
  3. Asus Eee PC 1008ha Screen Replacement: step 3, image 1 of 2 Asus Eee PC 1008ha Screen Replacement: step 3, image 2 of 2
    • Use your fingers to lift the battery and gently disconnect the wires from the base.
  4. Asus Eee PC 1008ha Screen Replacement, LCD Screen: step 4, image 1 of 2 Asus Eee PC 1008ha Screen Replacement, LCD Screen: step 4, image 2 of 2
    • Using the Phillips #00 screwdriver, unscrew the 4mm screws from the rightmost circuit board.
    • Carefully pull the circuit board away from side of device base.
  5. Asus Eee PC 1008ha Screen Replacement: step 5, image 1 of 3 Asus Eee PC 1008ha Screen Replacement: step 5, image 2 of 3 Asus Eee PC 1008ha Screen Replacement: step 5, image 3 of 3
    • Using the Phillips #00 screwdriver, unscrew the 4mm screws attaching screen to base from both sides.
    • Gently lift the screen portion from the base.
  6. Asus Eee PC 1008ha Screen Replacement: step 6, image 1 of 2 Asus Eee PC 1008ha Screen Replacement: step 6, image 2 of 2
    • Using the Plastic Opening Tool, pry the six small chits from the face of the screen portion.
    • Using the Phillips #00 screwdriver, unscrew the two 2mm and four 4mm screws from underneath the chits.
  7. Asus Eee PC 1008ha Screen Replacement: step 7, image 1 of 2 Asus Eee PC 1008ha Screen Replacement: step 7, image 2 of 2
    • Slide the Plastic Opening Tool under the edge of the screen bezel to release the front panel of the screen.
  8. Asus Eee PC 1008ha Screen Replacement: step 8, image 1 of 2 Asus Eee PC 1008ha Screen Replacement: step 8, image 2 of 2
    • Using the Phillips #00 screwdriver, unscrew the 2mm screws from the perimeter of the screen.
    • Use your fingers to hold the screen and carefully lift it from the base.
  9. Asus Eee PC 1008ha Screen Replacement: step 9, image 1 of 2 Asus Eee PC 1008ha Screen Replacement: step 9, image 2 of 2
    • Use your fingers to peel back the adhesive tape located on the back of the screen.
    • Disconnect the wire from the screen.
Michael Dooley
138 Reputation
3 Guides authored
Cal Poly, Team 21-52, Johann Spring 2013 Member of Cal Poly, Team 21-52, Johann Spring 2013
CPSU-JOHANN-S13S21G52
4 Members
11 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 3,088
