Asus Eee PC 1008ha Trackpad Mouse Clicker Replacement
  1. Asus Eee PC 1008ha Trackpad Mouse Clicker Replacement, Trackpad Mouse Clicker (the button's on the bottom of the trackpad): step 1, image 1 of 1
    • Use an opening too to carefully separate the palm rest assembly from the base of the laptop.
    • Move the opening tool around the perimeter of the palm rest and the base and use it as a wedge.
    • You will need to undo the clips holding the two parts together with the opening tool. Be careful not to break the clips.
  2. Asus Eee PC 1008ha Trackpad Mouse Clicker Replacement: step 2, image 1 of 2 Asus Eee PC 1008ha Trackpad Mouse Clicker Replacement: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • Use a spudger to open the cable locks and remove the ribbon cables using your hands or tweezers.
    • Using a Phillips #00 screwdriver, remove the two 4 mm screws on either side of the circuit board.
Michael Dooley
138 Reputation
3 Guides authored
Cal Poly, Team 21-52, Johann Spring 2013 Member of Cal Poly, Team 21-52, Johann Spring 2013
CPSU-JOHANN-S13S21G52
4 Members
11 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 11
All Time: 916
