Asus Eee PC 1201HAB Hard Drive Replacement
  1. Asus Eee PC 1201HAB Hard Drive Replacement, Keyboard: step 1, image 1 of 2 Asus Eee PC 1201HAB Hard Drive Replacement, Keyboard: step 1, image 2 of 2
    • Use a plastic opening tool and carefully pry the top panel from the base.
  2. Asus Eee PC 1201HAB Hard Drive Replacement: step 2, image 1 of 3 Asus Eee PC 1201HAB Hard Drive Replacement: step 2, image 2 of 3 Asus Eee PC 1201HAB Hard Drive Replacement: step 2, image 3 of 3
    • Slowly lift the keyboard from the base.
    • Disconnect the attached ribbon from under the keyboard.
  3. Asus Eee PC 1201HAB Hard Drive Replacement: step 3, image 1 of 1
    • Remove the keyboard.
  4. Asus Eee PC 1201HAB Hard Drive Replacement, Hard Drive: step 4, image 1 of 2 Asus Eee PC 1201HAB Hard Drive Replacement, Hard Drive: step 4, image 2 of 2
    • Lay the laptop with the back facing up.
    • With a Phillips #0 screwdriver, remove the eight 6mm screws on the back of the laptop.
  5. Asus Eee PC 1201HAB Hard Drive Replacement: step 5, image 1 of 3 Asus Eee PC 1201HAB Hard Drive Replacement: step 5, image 2 of 3 Asus Eee PC 1201HAB Hard Drive Replacement: step 5, image 3 of 3
    • Slide the tabs outward to remove the battery.
  6. Asus Eee PC 1201HAB Hard Drive Replacement: step 6, image 1 of 2 Asus Eee PC 1201HAB Hard Drive Replacement: step 6, image 2 of 2
    • Flip the device so that you are facing the screen.
    • Remove the ten 4mm screws on the silver panel under the keyboard using a Phillips #0 screwdriver.
  7. Asus Eee PC 1201HAB Hard Drive Replacement: step 7, image 1 of 3 Asus Eee PC 1201HAB Hard Drive Replacement: step 7, image 2 of 3 Asus Eee PC 1201HAB Hard Drive Replacement: step 7, image 3 of 3
    • Using a plastic opening tool, remove the top panel of the laptop.
  8. Asus Eee PC 1201HAB Hard Drive Replacement: step 8, image 1 of 2 Asus Eee PC 1201HAB Hard Drive Replacement: step 8, image 2 of 2
    • Using a Phillips #0 screwdriver, remove the four 4mm screws connecting the hard drive.
  9. Asus Eee PC 1201HAB Hard Drive Replacement: step 9, image 1 of 1
    • Remove and replace the hard drive.
Katherine Chan
353 Reputation
2 Guides authored
UC Davis, Team S7-G3, Lore Fall 2018 Member of UC Davis, Team S7-G3, Lore Fall 2018
UCD-LORE-F18S7G3
3 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 32
All Time: 856
