Asus Eee PC 1215N RAM Replacement
  1. Asus Eee PC 1215N RAM Replacement, Battery: step 1, image 1 of 2 Asus Eee PC 1215N RAM Replacement, Battery: step 1, image 2 of 2
    • Turn the power off and turn the netbook upside down.
    • Slide both battery catches together to release the battery.
    • Slide the battery out.
  2. Asus Eee PC 1215N RAM Replacement, RAM: step 2, image 1 of 3 Asus Eee PC 1215N RAM Replacement, RAM: step 2, image 2 of 3 Asus Eee PC 1215N RAM Replacement, RAM: step 2, image 3 of 3
    • Locate the memory compartment.
    • Using a Plastic Opening Tools, remove the screw rubber cover.
    • Remove the screw.
  3. Asus Eee PC 1215N RAM Replacement: step 3, image 1 of 1
    • Use a Plastic Opening Tools near the screw hole to release the cover.
    • Remove the cover
  4. Asus Eee PC 1215N RAM Replacement: step 4, image 1 of 2 Asus Eee PC 1215N RAM Replacement: step 4, image 2 of 2
    Tool used on this step:
    Spudger
    $3.99
    Buy
    • Using a Spudger, push both right and left metal clip to release one of the RAM module.
    • Slide out the RAM module.
    • Do the same with the second RAM module if necessary.
Gaetan
9,613 Reputation
18 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 13
All Time: 3,061
