Asus Eee PC 900 RAM Replacement
  1. Asus Eee PC 900 RAM Replacement, Battery: step 1, image 1 of 3 Asus Eee PC 900 RAM Replacement, Battery: step 1, image 2 of 3 Asus Eee PC 900 RAM Replacement, Battery: step 1, image 3 of 3
    • Slide the battery's locking tabs from the locked position to unlocked positions.
    • The right tab is unlocked when a red dot is showing.
    • The left tab will have to be held in the unlocked position in order to release the battery.
  2. Asus Eee PC 900 RAM Replacement: step 2, image 1 of 1
    • Slide the battery out while holding the left locking tab in the unlocked position.
  3. Asus Eee PC 900 RAM Replacement, RAM: step 3, image 1 of 2 Asus Eee PC 900 RAM Replacement, RAM: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the sticker from the RAM compartment using a pair of tweezers.
  4. Asus Eee PC 900 RAM Replacement: step 4, image 1 of 2 Asus Eee PC 900 RAM Replacement: step 4, image 2 of 2
    • Remove the two 4.8 mm screws using a Phillips #0 screwdriver.
  5. Asus Eee PC 900 RAM Replacement: step 5, image 1 of 1
    • Open up the cover from the bottom by carefully prying it open with a plastic opening tool.
    • Be gentle when prying open the cover in order to not damage it.
  6. Asus Eee PC 900 RAM Replacement: step 6, image 1 of 1
    • Remove the back cover by pulling up on the side that had the screws.
  7. Asus Eee PC 900 RAM Replacement: step 7, image 1 of 2 Asus Eee PC 900 RAM Replacement: step 7, image 2 of 2
    • Use a spudger to push the top of the pin on the right towards the right (so it isn't holding the RAM chip).
    • Do the same for the left pin. Push the top of the pin towards the left.
    • The RAM should pop up.
  8. Asus Eee PC 900 RAM Replacement: step 8, image 1 of 1
    • Remove the RAM chip by grabbing the top of the chip and pulling it upwards.
    • Be gentle when removing the RAM because it is a very delicate part and you do not want to break any of the pins in the computer.
5 other people completed this guide.
Brian Carreon
300 Reputation
2 Guides authored
Cal Poly, Team 3-27, Amido Winter 2012 Member of Cal Poly, Team 3-27, Amido Winter 2012
CPSU-AMIDO-W12S3G27
4 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 27
All Time: 9,454
