Asus EeeBook X205TA Battery Replacement
  1. Asus EeeBook X205TA Battery Replacement, Battery: step 1, image 1 of 2 Asus EeeBook X205TA Battery Replacement, Battery: step 1, image 2 of 2
    • Unscrew all ten 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
  2. Asus EeeBook X205TA Battery Replacement: step 2, image 1 of 1
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA Battery Replacement: step 3, image 1 of 2 Asus EeeBook X205TA Battery Replacement: step 3, image 2 of 2
    • Unscrew all six 2mm screws using Philips #2 screws along the edges of the L-Shaped battery.
    • Any tape or cords that run along the battery should be carefully pushed to the side.
  4. Asus EeeBook X205TA Battery Replacement: step 4, image 1 of 1
    • Disconnect the battery from the motherboard by pulling the No-Fuss Ribbon cables out of the connector.
  5. Asus EeeBook X205TA Battery Replacement: step 5, image 1 of 1
    • Carefully lift the battery out of the laptop.
Follow the guide in reverse order to reassemble the device.
8 other people completed this guide.
Lorena Santiago
712 Reputation
4 Guides authored
USF Tampa, Team 2-2, Sullivan Fall 2016 Member of USF Tampa, Team 2-2, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G2
3 Members
10 Guides authored
11 Comments
By any chance , Can we run this laptop without battery ? I mean directly from AC ? Please suggest
Sourabh Verma - Reply
No, you must have the battery on.
Tayler Grant -
is this under warenty
bla bla - Reply
If you have one….
Tayler Grant -
My battery is stuck on orange led mode. My laptop cannot identify the battery….
Tayler Grant - Reply
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 70
All Time: 14,054
