Asus EeeBook X205TA Screen Assembly Replacement
Lorena Santiago
Lorena Santiago and 4 other contributors
Last updated on October 8, 2019
10 - 15 minutes
Moderate
Introduction
Go to step 1
This guide will help you replace your Asus EeeBook X205TA screen in case the screen is broken, damaged or worn out. If disposing of the screen, please follow the laws and regulations for proper disposal.
This guide only covers removing the entire LCD screen assembly.
iFixit earns commission when you buy through these links.
  1. Asus EeeBook X205TA Screen Assembly Replacement, Screen Assembly: step 1, image 1 of 2 Asus EeeBook X205TA Screen Assembly Replacement, Screen Assembly: step 1, image 2 of 2
    • Unscrew all 10 screws located on the bottom of the laptop using 2mm Phillips Screwdriver.
    • Keep in mind that some of the screws vary in length, so keep track of which screws were placed in each hole.
  2. Asus EeeBook X205TA Screen Assembly Replacement: step 2, image 1 of 1
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA Screen Assembly Replacement: step 3, image 1 of 3 Asus EeeBook X205TA Screen Assembly Replacement: step 3, image 2 of 3 Asus EeeBook X205TA Screen Assembly Replacement: step 3, image 3 of 3
    • Unscrew the four screws using Philips #2 screwdriver that connect the screen to the inside of the case for the laptop.
  4. Asus EeeBook X205TA Screen Assembly Replacement: step 4, image 1 of 1
    • Unplug the No-Fuss Ribbon connector of the screen from the motherboard.
    • Carefully lift the screen away from the case.
3 other people completed this guide.
Lorena Santiago
712 Reputation
4 Guides authored
USF Tampa, Team 2-2, Sullivan Fall 2016 Member of USF Tampa, Team 2-2, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G2
3 Members
10 Guides authored
One Comment
What's that small black screen hanging out from the laptop
Tayler Grant - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 9
All Time: 2,435
