Asus F555LA-AB31 RAM Replacement
  1. Asus F555LA-AB31 RAM Replacement, RAM: step 1, image 1 of 1
    • Remove the Phillips #0 screw holding the RAM access panel in place.
    • Gently lift up on the edge of the panel to remove it.
  2. Asus F555LA-AB31 RAM Replacement: step 2, image 1 of 1
    • With the panel removed, The single upgradable RAM slot is easily accessible.
    • If RAM is already installed, it can be removed by gently pulling the retainers sideways away from the RAM to release it.
    • To install RAM, slide the DIMM into the socket at an angle of approximately 20 degrees from flat. Make sure the notch in the RAM module aligns with the notch in the socket. Gently push down on the RAM module until the retainers click into place.
To reassemble your device, reinstall the access panel by following these instructions in reverse order.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 33
All Time: 1,238
