Asus G73JH-RBBX05 RAM Replacement
  1. Asus G73JH-RBBX05 RAM Replacement, RAM: step 1, image 1 of 1
    • Locate the two, 4mm screws on the back of the laptop and remove them using a PH0 screwdriver.
  2. Asus G73JH-RBBX05 RAM Replacement: step 2, image 1 of 1
    • Use the plastic spudger to remove the panel.
  3. Asus G73JH-RBBX05 RAM Replacement: step 3, image 1 of 2 Asus G73JH-RBBX05 RAM Replacement: step 3, image 2 of 2
    • Push down the metal clips and remove the RAM.
4 other people completed this guide.
Trevor Sprosty
409 Reputation
3 Guides authored
Cal Poly, Team 22-11, Maness Winter 2017 Member of Cal Poly, Team 22-11, Maness Winter 2017
CPSU-MANESS-W17S22G11
3 Members
5 Guides authored
1 Guide Comment
Unfortunately, not very helpful when the only one that needs replacing is the only one not noted in this guide. Under the inside of the board, right behind the third RAM stick, there is a fourth that requires almost a total disassembly of the unit to access.
nekospacer - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 814
