Asus K50IJ Fan Replacement
Kyle Starbird
Kyle Starbird and 5 other contributors
Last updated on December 15, 2017
No estimate
Easy
Introduction
Go to step 1
Fans can overheat and stop working. This guide will help you be able to remove and replace the fan inside the ASUS K50IJ.
Tools
  1. Asus K50IJ Fan Replacement, Battery: step 1, image 1 of 1
    • Slide the tab over to unlock the battery cover located on the bottom-left corner of the laptop.
  2. Asus K50IJ Fan Replacement: step 2, image 1 of 3 Asus K50IJ Fan Replacement: step 2, image 2 of 3 Asus K50IJ Fan Replacement: step 2, image 3 of 3
    • Lift the exposed lip and remove the battery cover.
  3. Asus K50IJ Fan Replacement: step 3, image 1 of 3 Asus K50IJ Fan Replacement: step 3, image 2 of 3 Asus K50IJ Fan Replacement: step 3, image 3 of 3
    • Press the tabs on the battery and lift them. The battery should come out easily.
  4. Asus K50IJ Fan Replacement, Fan: step 4, image 1 of 3 Asus K50IJ Fan Replacement, Fan: step 4, image 2 of 3 Asus K50IJ Fan Replacement, Fan: step 4, image 3 of 3
    • Using the PH1 screwdriver, remove the four 4 .75 mm screws that are located on the vent panel.
  5. Asus K50IJ Fan Replacement: step 5, image 1 of 1
    • Remove the one .5 mm screw located in the top right corner of the battery compartment.
  6. Asus K50IJ Fan Replacement: step 6, image 1 of 2 Asus K50IJ Fan Replacement: step 6, image 2 of 2
    • Remove the bottom panel by sliding it toward the hinges and lifting the back panel up.
  7. Asus K50IJ Fan Replacement: step 7, image 1 of 1
    • Unplug the wire cable attached to the fan by pulling it out .
  8. Asus K50IJ Fan Replacement: step 8, image 1 of 2 Asus K50IJ Fan Replacement: step 8, image 2 of 2
    • Using the PH1 screwdriver, remove the 3 .75mm screws labeled as 1, 2, and 3 on the fan. NOTE these screws have the labels "1", "2", and "3" next to them.
    • Lift the fan up with your fingers.
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 7
All Time: 912
