Asus K55N-DS81 Rear Panel Replacement
  1. Asus K55N-DS81 Rear Panel Replacement, Battery: step 1, image 1 of 1
    • Flip the laptop over, such that the bottom of the laptop is facing upwards.
    • Ensure that the laptop is powered off prior to following this guide.
  2. Asus K55N-DS81 Rear Panel Replacement: step 2, image 1 of 2 Asus K55N-DS81 Rear Panel Replacement: step 2, image 2 of 2
    • Pull the latch to the right of the battery to the right.
  3. Asus K55N-DS81 Rear Panel Replacement: step 3, image 1 of 2 Asus K55N-DS81 Rear Panel Replacement: step 3, image 2 of 2
    • Pull the latch to the left of the battery to the left. Hold the latch open with a finger to prevent it from closing.
  4. Asus K55N-DS81 Rear Panel Replacement: step 4, image 1 of 2 Asus K55N-DS81 Rear Panel Replacement: step 4, image 2 of 2
    • While holding the second latch from the previous step, use another hand to reach underneath the battery.
    • Pull the battery upwards and away from the laptop to remove it.
  5. Asus K55N-DS81 Rear Panel Replacement, Rear Panel: step 5, image 1 of 2 Asus K55N-DS81 Rear Panel Replacement, Rear Panel: step 5, image 2 of 2
    • Using a JIS #00 screwdriver, unscrew the two 5 mm screws on either side of the laptop panel.
  6. Asus K55N-DS81 Rear Panel Replacement: step 6, image 1 of 3 Asus K55N-DS81 Rear Panel Replacement: step 6, image 2 of 3 Asus K55N-DS81 Rear Panel Replacement: step 6, image 3 of 3
    • Remove the panel by pushing away from the laptop until the panel is free of the laptop.
    • Lift to remove the panel.
Elliott Beckner
543 Reputation
4 Guides authored
IUPUI, Team S2-G1, Baechle Fall 2018 Member of IUPUI, Team S2-G1, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G1
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 410
