Asus K55VD DVD Player Replacement
  1. Careful: step 1 is sourced from a guide that's marked as in-progress.
    • Power off the device completely
    • Flip the device over to its back cover.
    • Use the switches to release the battery from its adapter.
  2. Asus K55VD DVD Player Replacement, Hard Drive: step 2, image 1 of 2 Asus K55VD DVD Player Replacement, Hard Drive: step 2, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the two 1.5 mm screws in the smaller portion of the bottom cover.
    • After removing the screws, remove the smaller cover.
  3. Asus K55VD DVD Player Replacement: step 3, image 1 of 1
    • Use a Phillips #0 screwdriver to remove the 1.5 mm screws that hold down the hard drive.
  4. Asus K55VD DVD Player Replacement: step 4, image 1 of 2 Asus K55VD DVD Player Replacement: step 4, image 2 of 2
    • Remove the hard drive from the slot.
    • Remove the hard drive from its shell.
  5. Asus K55VD DVD Player Replacement, Optical Disk Drive: step 5, image 1 of 1
    • Using the the Philips #0 Screwdriver remove highlighted screws.
  6. Asus K55VD DVD Player Replacement: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Lift plastic cover with tweezers.
    • Remove screw.
  7. Asus K55VD DVD Player Replacement: step 7, image 1 of 1
    • Lift keyboard panel with plastic pry tool to remove.
  8. Asus K55VD DVD Player Replacement: step 8, image 1 of 2 Asus K55VD DVD Player Replacement: step 8, image 2 of 2
    • Unhook all ribbons to remove keyboard panel completely.
  9. Asus K55VD DVD Player Replacement: step 9, image 1 of 2 Asus K55VD DVD Player Replacement: step 9, image 2 of 2
    • Slide the DVD Player outward.
One Comment
LOL if you want to get out drive, open dvd drive, turn laptop off, remove screw cover, unscrew, pull the drive out, done :D This is stupidly overcomplicated and unnecessary.
Luke Malatinsky - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 1,181
