Introduction
If a computer's fan is faulty, there will likely be overheating error messages occurring. If overheating does occur, the CPU could be damaged.
Step 1 Battery
Careful: step 1 is sourced from a guide that's marked as in-progress.
Flip the device over to its back cover.
Use the switches to release the battery from its adapter.
Use a Phillips #0 screwdriver to remove the two 1.5 mm screws in the smaller portion of the bottom cover.
After removing the screws, remove the smaller cover.
Remove all 12 screws from the bottom cover with a Phillips #0 screwdriver.
The single screw in the middle of the bottom cover is shorter than the rest.
7 other people completed this guide.
2 Comments
At step 5, you should also unscrew the bottom silver screw and unplug the wifi antennas.
